The heading says it all. What would you guys recommend in terms of a nailgun and style of nail to install wood T1-11 siding. Thanks for the help.
DIA
where,
on what?
Thius product is often used as a sheathing and siding all-in-one. If in a seismic zone, you'd have to meet shear waall requirements,
I believe theree is a Bostich and a Hitachi pnuematic siding oil nailer often recommended is aall you need is siding nails.
Minnesota, to enclose the porch on a rental property - 2x4 stud walls. Thanks.
I've used a Hitachi siding nailer to attach this type of siding for years. I think the model is the NV65. Nails are easy to find and the gun will run forever. Are you in the cities? I know most rental joints rent the gun if you need it for only one job.If you want to go the hand nail route, hard to beat a Maize nail. Just remember to pre-prime all exposed wood BEFORE you install it- esp if it is close to grade- or use a pre-primed panel, such as LP's Smart Panel.good luck!knowledge without experience is just information.... Mark Twain
Politicians, like diapers, need to be changed often...and for the same reason. (bumber sticker)
http://www.cobrajem.com
I use a Hitachi framing nailer with a flush attachment.
