What paint / texture sprayer will handle spray-on waterproofing?
daen | Posted in Tools for Home Building on August 9, 2010 11:59am
I am building my own home and workshop. I am building it out of an ICF product called Rastra. This is a styrofoam pellet and concrete mix poured into giant blocks.
http://www.rastra.com/
The home and the shop are built into hillsides and so some of the walls will be below grade. Although they are in the desert southwest, I have chosen to apply waterproofing. I figure it is cheaper to do now than wish I had later. Ground moister content is non-existant, but we do get some tremendous downpours at times.
I found a new barrel of Eco-Flex liquid rubberized waterproofing. It was surplus and cheap. http://www.aquasealusa.com/eco-flex.htm
Since this is a one-time deal, I planned to roll the product on. I had read some other blogs and this was an effective method for others. However, the surface texture of the Rastra is so rough compared to poured concrete or a CMU block that getting coverage in all the recesses has turned the job into a much bigger task than anticipated.
The blogs also discuss some folks spraying it on. However, they indicate it requires a “big” spray system. Not one of the $199 sale items at Home Depot or Lowes. The blogs also indicate that you should NOT get a rental unit because you cannot get it clean enough afterwards. After using the roller this past weekend, I can believe that! So once you commit a spray unit to the cause, it is pretty much dedicated.
I have seen several used paint sprayers on Craigslist. If the unit is cheap enough I can justify “ruining” it for the cause. It could even have some issues as long as it functioned.
My question for this discussion is what do people consider the minimum sprayer to use on a product like this. I am looking for brand and model suggestions since I know nothing about sprayer specifics. The blogger that sprayed this stuff for a living had a dedicated Graco Mark V.
A second long shot question: anyone know somebody in the Phoenix, AZ area that has a sprayer already used with this type of stuff that would hire it out?
Thanks in advance.
-dc
    xxPaulCPxx | Aug 10, 2010 12:42pm | #1
    I went through similar when looking to spray a super thick primer, I eventually found a sprayer powerful enough but I had to look for a long time.  I think the tip size and GPM are your key search items, look for sprayers that can run more than one gun at a time.
    TexSpray Mark V Specifications
    • Max Tip Size: .039
    • Max Working Pressure: 3300 psi (227 bar)
    • Max Delivery Rating: 1.35 gpm (5.1 Lpm)
    • Motor Size: Industrial Grade 2.8 hp Brushless DC
  2. Scott | Aug 10, 2010 02:04pm | #2
    The guy that did ours had a dedicated gas powered unit that looked similar to a pressure washer setup (though I'm sure it wasn't). You might be able to rent one.
  3. [email protected] | Aug 17, 2010 03:44pm | #3
    Undercoating gun
    What you need is an undercoating gun, and a large compressor.  They use about 8-cfm at 40 to 50-psi.
A New Approach to Foundations
