What ‘s the best grout for Mosaic tile?
| Posted in General Discussion on May 25, 1999 07:58am
Just finishing my walkin shower. Used nonsanded grout for the walls. Thinking of using sanded on the mosaic tile on the floor. Any advise on the using sanded vs nonsanded? Thanks Brent
  1. Guest_ | May 24, 1999 05:53pm | #1
    Brent,
    Whether you use sanded or un-sanded grout really depends on the size of your grout joint. If it's over an 1/8" then use sanded grout. . . with caution though. . . the sand could "scratch" your tile. It would be best to test this first. Also, you might want to add a like latex additive to the grout for added strength since it's on the floor.
    Joseph Fusco
    1. Guest_ | May 24, 1999 06:44pm | #2
      *I typically use sanded grout on joints 1/8" wide and wider and non-sanded on smaller joints. As Joe mentioned...make sure your tile wont scratch but assuming the tile is rated for floor use it should be OK. Sand adds strength to the grout. Mix with a latex additive and seal the joints after curing time recommended by the sealer manufacturer.Dave
      1. Guest_ | May 24, 1999 09:51pm | #3
        *If you get a modified grout, such as Custom's Polyblend, the most common on the west coast, do NOT use any additives. They are already in the grout mix.
        1. Guest_ | May 24, 1999 11:00pm | #4
          *Good point...read the directions on the bag!!
          1. Guest_ | May 25, 1999 06:57am | #5
            *Mike,
            Had a chance to check the six boxes of Custom's Polyblend grout I have in the shop. . . no mention of "not" to add any additives. I'm wondering were you got this info from? I use an additive sometimes with no ill effects so far.
            Joseph FuscoView Image
          2. Guest_ | May 25, 1999 06:59pm | #6
            *Joseph:My Polyblend Sanded Tile Grout box says:Combine el relleno con agua limpia y fresca y mezcla hasta que adquiera consistencia cremosa y tersa. No use aditivos. Plain as the nose on my face.On the front of the box features listed include:Polymer-modified---just add waterPerhaps there is a difference in sanded/nonsanded, Poly may come either with or without additive, then again, you like I have trouble accepting the word "not", as in "not possible", "not enough money", or "not another whatnot honey?!" Thor
          3. Guest_ | May 25, 1999 07:58pm | #8
            * Thor,
            After another inspection of the boxes of "non-sanded" grout. . . no such statements "No use aditivos." in either language! Might just be on your box. But, I'll check the sanded boxes to make sure.
            Joseph Fusco View Image
  2. brent_collins | May 25, 1999 07:58pm | #7
