What to Use to Plug holes in Steel Exterior Door
jimmiem | Posted in General Discussion on January 22, 2016 06:15am
I have a steel clad exterior door that has windows in the top half.  I have blinds over the door’s windows and I had to replace the blinds.  The new mounting hardware could not use the same holes as the original so I have exposed holes in the door.  Would like some suggestions on what material(s) to use to plug the holes.
  1. oldhand | Jan 22, 2016 06:46pm | #1
    how big are the holes?
    If you are talking about screw sized holes then bondo [auto body filler] will work perfectly.
    1. jimmiem | Jan 22, 2016 06:52pm | #2
      Holes
      Yes, #6 screw holes.
  2. DanH | Jan 22, 2016 07:00pm | #3
    Well, you could always plug them with screws.
  3. gfretwell | Jan 23, 2016 10:56am | #4
    Clean all the paint and primer away from the holes and nearby metal, fill with JB Weld. Then sand it down flat, prime and paint the door.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
