What you use for nail holes?
markob | Posted in Construction Techniques on February 6, 2013 04:23am
Hey just wondering what everyone uses to putty nail holes
  1. DanH | Feb 06, 2013 08:28pm | #1
    Toothpaste.
  2. calvin | Feb 06, 2013 08:29pm | #2
    mark
    for what?
    Stain or paint?
    Inside or out?
  3. markob | Feb 06, 2013 11:17pm | #3
    Inside and paint grade
    1. gfretwell | Feb 07, 2013 12:34am | #4
      Use something appropriate for the material with the nail hole.
      Drywall? Spackle
      Wood? Wood filler. Wood will puke spackle out over time if you have a lot of humidity
      1. markob | Feb 07, 2013 09:57am | #5
        It's for trimwork..I use painters putty but that doesnt leave a flawless fill..I'm looking for something for high end work where u could never even tell there was a nail hole there
        1. calvin | Feb 07, 2013 10:58am | #6
          mark
          I use Dap products for painted fill, but do put it on proud of the surface and sand later.  On occasion have mixed up some Durabond, dries hard-sandable-doesn't shrink much.  Used a product from Elmers-can't remember if I liked it-it froze up on a lazy night I didn't bring in the caulk bag.
          Have some WoodFiller from Minwax that I thought worked ok.
          One of the painters uses something I'd never seen b/4.  Looked like glazing in the can, but does harden and sand.  I should have written the name down.  It's from his paint supplier I would guess.
          At any rate, most of the painters I use want to do the filling and do a good job of it.
          To me, there's no difference in high and regular-perfect will be close enough for the job.
          Well, there is some difference...............
          1. markob | Feb 07, 2013 12:22pm | #7
            Durabond is a pretty good idea..I saw something like that..it was called tough something at lowes..it was a powder that u mix up...and as for that glazing your sayin I think there is something called glazing putty in a red can..never used it tho...I guess ill just have to actually test out the products and see for myself
          2. calvin | Feb 07, 2013 06:08pm | #8
            mark
            The glazing putty is just that-Glazing.
            It will never harden (much) and has some oil in it I believe-not good if you're topcoating with latex (I don't think).
            The stuff I saw, looked like glazing in the can (more smooth in consistancy, but did harden like spackle.
            There's something that's used with Azek-Top and Bond or Top'n'bond, that might work good.  Never saw it, never used it.
Mortar for Old Masonry
