What’s the best gutter hanger system for 5″ gutters, for diy installation?
pizza | Posted in General Discussion on October 3, 2012 10:09am
Hi. I was researching gutter hangers recently to help me fix my sagging 28 foot long gutters. What’s the strongest system out there? Any suggestions? What do you think about the two I’ve found-one called the HangFast and one called the Sampson Hanger. The HangFast claims to hold 297 lbs but it didn’t say if that was the capacity for one or a whole line of them. The Sampson on the otherhand says they ARE the strongest and they show it holding an 80 lb weight alone on one with test results comparing it to the competitors. I’m leaning toward the Sampson ones.
I found another system that is a continuous piece of aluminum (called the Truss Dura trac)that gets affixed behind the gutter onto the fasci and then the gutter sort of clicks into it (no holes into the fascia) but it seems that it is only offered by contractors who will install it and not sold to diy people.
  1. DanH | Oct 03, 2012 08:30pm | #1
    The best hanger system is the one uses enough hangers to hold the gutter.  Most "builder" gutter installs have only half the hangers they need.
    hammer1 | Oct 04, 2012 03:07pm | #2
    I like these but I haven't used many others, we call them universal hangers. Snap a line on the fascia, screw the hangers on the line hitting each rafter, 16" or 24" OC. The gutter is installed by hanging it on the front and swinging it up into the rear clips, pretty easy even for one person. They stand up to the ice and snow we get, even bad ice dams.
    1. pizza | Sep 09, 2014 04:23pm | #4
      Gutter hanger
      Those clearly look very weak and are very weak for my situation. There's absolutley no bent gusset or even a sheet metal bend where it counts at the bend near the fascia.
      I have a metal roof that, when snow is on it, and it starts sliding off and hanging onto the gutters they literally twist the gutter almost 90 degrees and pop most of the hangers out of the front lip. Lot of snow last year and I had to use an awesome roof rake that helped alot with the problem. This year however I plan to add snow guards on the roof as well as the strongest hangers I can find.
  3. pizza | Sep 09, 2014 04:16pm | #3
    strongest gutter hangers
    DanH; I'm revisiting this project that I haven't got to but I was looking for a specific type/design that is the strongest.
    1. DanH | Sep 09, 2014 07:58pm | #7
      The point is that the particular hanger you use is not nearly as important as how many you use and how well they're anchored.
        deadnuts | Sep 09, 2014 11:06pm | #8
        What's your point, again?
    deadnuts | Sep 09, 2014 07:23pm | #5
    hidden screw type hangers by Raytec
    IMO, the best gutter hanger for regular 5" or 6" K style gutters is made by Raytec. Most professsional seamless gutter installers around our area use these. You can buy them here:
    http://wimsattdirect.com/products/exterior-cladding/rainware/gutter-fasteners/hidden-hangers/raytec-gutter-hanger-5-w-screw.html?gclid=Cj0KEQjwyrqgBRDepamt-LWA2oABEiQAV7nwwFQwInhp0DK2Q-YudbhBg3Q1hqohjvOc8AziHPpQD8caAh-G8P8HAQ
    Remember: A gutter hanging system is only as good as the fascia it is attached to.
    Most production home fascias are attached (nailed)  to end grain lumber framing (trusses usually)  which is why snow and ice can tear them away from the house along with the gutter. We usually frame with sold 2x subfascias just for this reason. Our subfascias are attached with timber screws and our fascias are usually attached with SS wood screws.
  5. catmandeux | Sep 09, 2014 07:34pm | #6
    I have a lot of trees close to the house, so I  wanted a gutter guard when I did new gutters.  The  T-Rex  system from Alu-Rex , which is a hanger and guard system, seemed like a good idea.
    Was fairly easy to instal, It is inserted and crimped to the gutter on the ground, so the gutter does not flop around when lifting up the the roof.
     2 years, have not needed to clean the gutters, Gutters are securely held.  I'm happy with the system.
      deadnuts | Sep 09, 2014 11:22pm | #9
      Seems proprietary
      Where did  you buy the T-Rex components in order to install it yourself?
      1. catmandeux | Sep 10, 2014 06:34pm | #10
        Available in my area from roofing supply distributors.
        I'm in southern Ontario.  There are a number of companies that will show up on site with the seamless gutter machines, roll out what ever you need, and supply the required accessories, including the T-Rex or competing products.
        Edit:  Checked the Alu-Rex web site.  US partner is PlyGem, and is marketed as Leaf Relief Combo Hanger.   Not sure what the distribution system is like.
