What’s the difference?
oops | Posted in General Discussion on May 30, 2014 01:43am
What’s the difference between a feeder, a sub-feed and a branch circuit?
The question relates to what the service from the existing  house panel to a new detached garage/shop would be called..
Any other pertinent and  related information would be appreated.
    Mongo | May 31, 2014 02:22am | #1
    not an electrician
    1) The last point in a feed line is a current overprotection device. A circuit breaker, or a fuse, for example. The power line coming into your house that feeds the service panel is a feed line.
    2) A sub-feed would come off the main panel and feed a sub panel with overcurrent protection. So the sub feed runs between two breakers. I've seen it referred to as a "sub feed" or just a "feed".
    3) A branch circuit is what comes after the circuit breaker. There is no overcurrent protection anywhere on the branch. For a branch, the overcurrent protection is at the beginning of the branch, In the service panel.
    Think of it as feeders feed into circuit breaker. Branches exit the circuit breaker. A line that has protection on both ends, ie, it exits a service panel to feed a sub-panel? That is sometimes called a sub-feed.
  2. gfretwell | May 31, 2014 10:46am | #2
    The NEC really only defines "feeder" and "Branch Circuit". A feeder is anything between the service disconnect and the last over current device, a branch circuit is beyond the last over current device to equipment served.
    "Sub-feeder" might be a feeder after a feeder but it is not defined in the NEC and there are no special rules.
Outdoor Lighting
