Whats this now?
andybuildz | Posted in Tools for Home Building on May 24, 2006 05:48am
I do have a picture but I haven’t downloaded it into my puter yet and I have a feeling someone’ll answer this pretty quickly so…but if not I’ll download the pic from my camera and post it…I know, what a tease.
I’ve bever seen this little tool before but fell in love with it when one of my guys turned me on to it. Someone gave it to him so he has no idea where to purchase it.
It looks like a nut driver you put in you drill chuck. It has a phillips head sunk in about an 1/8th of an inch or so. You screw rock up with it. It sets the screw “perfectly” in dept and even leaves a soft ring/hole depression in the rock that fills with mud beautifully. Why haven’t I seen more of these around. Personally it does a better job than my screw shooter. Great invention and probably costs under five bucks.
Anyone know where I can buy one of these lil’ suckers???
a…
If Blodgett says, Tipi tipi tipi it must be so!
TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
    MarkH | May 24, 2006 06:22am | #1
    It's a drywall dimpler.  There are a few styles.
    http://www.vermontamerican.com/Products/productdetail.htm?G=157751&GRP=169581
    http://power-tools.gillroys.com/Drills_&_drill_bits/Drill_bits/Drywall_Dimpler-s369284.html
    http://www.toolking.com/ProductInfo.aspx?productid=1824
      MarkH | May 24, 2006 06:42am | #2
      Bosch badged, same stuff, at Lowes.
      http://www.lowes.com/lowes/lkn?action=productList&N=0&Ntk=i_products&Ntt=drywall%20screw%20setter
      1. andybuildz | May 24, 2006 06:51am | #5
        Says Home Depot carries them too but never saw them there not that I was looking before this.
        Why pay so much more money for the reverse function when you can just put your drill in reverse.If Blodgett says, Tipi tipi tipi it must be so!
        1. omnimax | May 24, 2006 07:08am | #6
          The "reverse function" of the $15 one let's you raise the outside ring so that it doesn't contact the drywall as you're backing out a screw.
          1. andybuildz | May 24, 2006 07:48am | #7
            why would you need to raise the ring? It'd back out anyway, right?If Blodgett says, Tipi tipi tipi it must be so!
          2. omnimax | May 24, 2006 07:57am | #8
            If the head of the screw is recessed into the drywall and the outer ring is forced into contact with the drywall so the bit can engage the screw, damaging the surface of the drywall is a posibility.
            MarkH | May 24, 2006 01:27pm | #9
            The $15 one has a built in clutch and takes drywall bits.  The cheaper ones are a one shot deal.
    2. andybuildz | May 24, 2006 06:47am | #3
      Thanks Mark...These things are unbelieveably good.If Blodgett says, Tipi tipi tipi it must be so!
      1. huddledmass | May 24, 2006 06:49am | #4
        they work good with an impactor because of the high rpm's makes it feel like a drywall gun
         "I hate quotations.  Tell me what you know"  Ralph Waldo Emerson
  2. Jer | May 24, 2006 02:10pm | #10
    You have to look, but you will find them at the box stores. Been using them for years. I don't do enough rockin' anymore to justify dragging out the corded sheetrock gun. The little tip that can gets carried around with the little impact driver that can. Zip zip zip...
    IMERC | May 24, 2006 02:15pm | #11
    Lowes.. 15$ for rhe clutched model...
    2$ for the fixed jobbie...
    WOW!!! What a Ride!
    1. andybuildz | May 24, 2006 02:28pm | #12
      Lowes even found its way to the mtns of Colorado...ut ohIf Blodgett says, Tipi tipi tipi it must be so!
        IMERC | May 24, 2006 02:41pm | #13
        sure beats the snot outta HD...
        the guy with the dogs...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
        1. rez | May 24, 2006 08:40pm | #15
          yep
          be Lowes
          half of good living is staying out of bad situations
            Sphere | May 25, 2006 01:45am | #16
            Along the same idea is a new improved magnetic bit holder, it has ring that holds the head of the screw besides the magnet in the shaft,,McFeelys has'em and so did my local Mom and pop yard..for 6.95.
            Don't use an impact driver, it will bust up the internal magnet ( rare earth are fragile) and make a bunch of sticky shrapnel...)
            Just a heads up.
            There is no cure for stupid. R. White.
        BossHog | May 24, 2006 03:06pm | #14
        I've used a couple of those $15 ones, and don't like 'em. You have to have the drill perfectly square to the drywall. Just a little off, and the thing kicks out too early. The magnets also fall out frequently, then the screws won't stay on the bit. And the clutch thingy wears out all too quickly.They're not bad for tacking a sheet up. But nothing beats a corded screw gun for putting the rest of the screws in, IMHO.
        ANYONE in YOUR organization is ALWAYS right if opposed by an outsider. Even if your soldier is wrong, he is right; that can be straightened out between the two of you later [V, in "The Mafia Manager"]
