whats wrong with Therma-true
Isamemon | Posted in General Discussion on November 6, 2004 07:29am
did not want to sdistract from another thread that was aksking about flooring and someone mentioned  that sometimes big advertising does not maean quality…..how very true….
however the example was therma true doors
what problems have people had with them. I have a house coming up with 2 french doors and three  single doors, all therma tru
I havent notice any call back problems with the few I have put in so far
maybe they have not been in my projects long enough ?
if they are a problem, what is a good alternative without spending tons of money
and wher I live , wood does not hold up
Edited 11/6/2004 12:31 pm ET by Isamemon
  1. Piffin | Nov 06, 2004 09:07pm | #1
    I've only used about a dozen TT doors but I have never found one that did not have a problem of one kind or another.
    Most have a shorter head jamb piece than threashold so the jamb is never square to hang or trimn to of expect a tight fit against weather.
    I am told that all door companies only make the door blanks and then their distributors asemble them into jambs so TTs in other parts of the country might be different. Another assembly problem is that several have had misaligned hinges and screws so crooked they kook like they were set by a drunk with a hammer or a rock instead of a tradesman with a screwdriver.
    My biggest complaint is about the structural integrity of the FG units. They have a very small wood stily so when you drill for lockset and deadbolt, there is almost no wood left. The wimpy thing then bows in at the top and bottom from wind pressure or just the weather strip. Within a couple months, the wind and moths are sailing thru the corners of the Therma Thru
      NickNukeEm | Nov 06, 2004 10:02pm | #2
      Wow.  We talking about the same door?  I've had nothing but good luck with TT doors, although I only install their FG models.  Jambs are square, fit is solid, no problem with the hinges.  If what you say about the mfr making the slab and farming out the rest is true, then it sounds as though the distributor where you got yours from is making the doors after a prolonged happy-hour fiesta.  As for the stile weakening the door, I didn't notice any flex, and I have yet to have a call back on any TT door I've installed.
      I highly recommend them and look forward to installing the TT doors, at least those we can get around these parts.
      1. Piffin | Nov 06, 2004 10:49pm | #5
        Replaced the same door twice and the third is still going bad. The owner finally gave up on that one and had me instal a storm door over it. First couple replacements were on my nickle for labour so I refuse to try it again.
        All the other problems are simply a PIA for me - to reseat hinges etc to have them working prooperly. I just don't need the hassle when I can get other doors that are good and walk themselves in.
          NickNukeEm | Nov 06, 2004 11:03pm | #6
          What else do you use?  Here we have a choice of either Masonite/Stanley or TT, unless I go to the House of Doors and have them custom order one from a mfgr I'm not familiar with.  I ditto Bobs thought on the stile, last one I put in had a plywood core that looked similar to an lvl, pretty solid to me.
          1. Piffin | Nov 07, 2004 03:24am | #11
            For full view, I like Ansdersen or marvin. For utility doors, Peachtree. I have seen displays of the masonite high end units that look good, but haven't used one yet. We have alsdo made some of our own doors.
            I used some Pellas several years ago and the doors were fine but the windows left me cold. So on this last job, I had a lot of doors and went with Pella over Marvin for a 20K difference, but I am pretty disappointed overall in this order and am likely to be careful about Pella in the future again
          2. donpapenburg | Nov 07, 2004 04:07am | #12
            I have a TT steel french door . The hinges are junk and the wind whisles through at the top and bottom corners of the weather striping.     If they farm out the casing that is not my fault . but I know what works and will not buy another TT door.   You are only as good as your last door.
          3. gdavis62 | Nov 08, 2004 02:22am | #29
            Masonite is the old Premdor with a new brand name.  If you didn't like Prem before, you will have the same dislike for them under the Masonite name.
            One of the steel door models Prem used to make, in their Dixon, TN plant, was one with rollformed 20 gage stiles and rails.  No wood in the door on the edges, except for a block at the lock prep.
            A great door design in a foamfilled steel model, IMHO.
            Don't know whether you can get them up where you are, but Benchmark "Legend" steel doors are quite good.  Their plant is in Fredericksburg, VA, and they were bought by Therma-Tru in '98.  Their product lines are entirely distinct from one another.  The "Legend" is all steel . . . no wood stiles or rails.
            NickNukeEm | Nov 16, 2004 01:40am | #32
            Unfreakingbelievable.  Got a call today from a couple for whom I installed an exterior door about 3 weeks ago.  Seems there's a gap at the top on the lock jamb of about 1/4"  Went out and took a 5' straightedge.  The door is bowed inward at the top and somewhat at the bottom.  It's flexed pretty good.  It's a TT FG with 9 lite window, so the rail is minimum.  First call back on a TT FG.  Guess I'll go with steel and insist on additional primer and paint next time...
            Talk about your timing.
            NickNukeEm | Nov 16, 2004 01:45am | #33
            Edit, BTW, Who's Gene Davis and what did they do with Bob Dylan?  I mean, Bob wrote most of this thread, right?  He change his moniker again?I never met a tool I didn't like!
          6. gdavis62 | Nov 16, 2004 02:52am | #34
            Yep.  Truth in journalism.  Bob Dylan never worked at Therma-Tru.
          7. dIrishInMe | Nov 16, 2004 03:13am | #35
            At least it's just the slab...  Should mean less hassle resolving the prob...  Be sure and let us know if TT give you a hard time about the warranty. Matt
          8. xMikeSmith | Nov 16, 2004 05:32am | #36
            gene, i asked at my lumber yard.. JT's.. they said they get TT from Brosco, Huttig &  a 3d one.. i think it was Clearey..
             and JT's does no assembly of the TT. ( they do assemble mulled Andersens )  the distributors are putting them togetherMike Smith   Rhode Island : Design / Build / Repair / Restore
          9. User avater
            NickNukeEm | Nov 17, 2004 12:22am | #38
            Supposedly HD is going to call for a rep.  Went out again and put a 6' level on the interior side of the door while it was open; 3/16 -  1/4" gap at the lockset.  If the rep won't authorize replacement, I will probably yank it and install a steel door, probably Stanley for lack of anything better at the immediate moment.  But it wouldn't be another TT.
      2. takenagain | Jun 21, 2017 07:11am | #39
        Thermatru junk...er, I mean fiberglass doors still made in pine
        THERMATRU JUNK IS WHAT I CALL MY DOOR. I HAVE A DUTCH COLONIAL AND DURING REMODEL A DOOR REP CAME OUT AND SAID GO WITH FIBERGLASS SO WE PURCHASED WHAT WE THOUGHT WAS A FIBERGLASS DOOR BECAUSE OF WEATHER PROOFING AND EXPOSURE TO ELEMENTS.  W E L L  LET ME EXPLAIN WHAT I GOT. I GOT A FIBERPLASS SKIN ON A PINE CORE. THE PINE CORE COMES ALL THE WAY TO THE EDGES SO THE EDGES ARE EXPOSED. THAT NOW BECOMES A PROBLEM BECAUSE ON THE HINGE SIDE AT THE BOTTOM I HAVE PINE WOOD ROT ABOUT FOUR INCHES FROM THE BOTTOM. WHY COULDNT THEY MAKE THE EDGES FIBERGLASS?
        A SECOND PROBLEM. NO ONE TELLS YOU THAT ALTHOUGH YOU HAVE THE COMFORT OF KNOWING YOU'RE DOING THE RIGHT THING IN BUYING A FIBERGLASS DOOR, THE DAMN THING IS INSTALLED WITH PINE TRIM CASING. I WAS NEVER EVEN GIVEN A CHOICE. I ASSUMED IF A SALESMAN IS TALKING THE BENEFITS OF FIBERGLASS THEN FIBERGLASS IT WILL BE.  I HAVE WOOD ROT AT THE BOTTOM OF THE CASING THAT YOU COULD PUT YOUR FINGER THROUGH, IN FACT SOME OF THE WOOD HAS ROTTED AWAY.
        i SUPPOSE AS A HOMEOWNER I SHOULDVE ASKED THE STUPID QUESTIONS, JUST THE DUMEST OF ALL QUESTIONS STARTING WITH NUMBER 1 AND ENDING WITH NUMBER 90. IF YOU HAVE LESS THAN 90 QUESTIONS WHEN PURCHASING ANYTHING, GO BACK TO YOUR NOTES AND COME UP WITH 90. AS FOR ME, MY 90TH QUESTION WOULD HAVE BEEN, "AND WHAT IS THE CASING MADE OF"
        THERMATRU JUNK
        1. calvin | Jun 21, 2017 09:24pm | #41
          Greetings
          Primed wood on doors, jambs and trim needs a finish coat, they will come primed.
          instalation needs to be perfect.  You don't just slap caulk behind and under the unit nor do you forget the proper flashing techniques.
          no rot jamb and trim bottoms can and should be offered, recommended, and ordered for the additional charge.
          Whomever offered ordered and installed might shoulda read the directions.  In this age of automatic, best practice is still the king.  Anything less isn't worth the effort.
    2. gdavis62 | Nov 06, 2004 10:29pm | #4
      In those dozen TT doors with which you had experience, was there a mix of fiberglass and steel?  You have mentioned fiberglass, but I wonder what your problems were with their steel products.
      In fiberglass, their Classic Craft product line is made with a big wide lock stile of LVL, faced with red oak at the show surface.  Their FiberClassic and Smooth Star lines both have finger jointed 5/4 thickness stiles, backed up with 22" lock blocks.
      They make two lines of steel doors, the cheapest of which is the Construction Series, with skins of .018 thickness, 5/4 stiles, and no lock block.  The Premium steel door has .021 thickness steel, and a 12" lock block.
      Therma-Tru is one of the few foamfill door companies that seeks to carry its name brand out to the builder, with advertising, packaging, and product labeling.  And when I say "door company," I mean slab maker, a business that takes steel, wood, and fiberglass components, and makes the foam-filled door leaves, or "slabs."
      It looks like Canada's Premdor will try to do the same as Therma-Tru now, since they have bought Masonite, and are using the recognized Masonite name for their door product lines, both exterior and interior.
      Neither of these door slab makers has any real control over the quality of the prehung product that lumberyards sell to contractors.  The prehanging assembly work, and the sourcing of all the other-than-slab components that go into the assemblies, are in the hands of the distributors, with names like Huttig, Brosco, and Carolina Builders.
      That said, I would never recommend a fiberglass door to someone, unless it was to be installed way back in under an overhang, so it was protected from weather and sunlight.  And I would only use the thicker-skinned Classic Craft, with its big wide LVL lock stile, never the FiberClassic or Smooth Star.
      Any hinged full-lite glass door, IMHO, should be outfitted with a triple-point lockset.  A full lite door is essentially just a frame around glass, without any torsional panel strength, and to latch one only at the regular 36" height, leaves an unsupported top corner, a long way away, to flap in the wind.
      Want cost-effective glass doors for the patio or terrace side of the house?  Get Pella ProLine, either slider or hinged.  You won't be sorry.
      1. Piffin | Nov 06, 2004 11:10pm | #7
        Check out Disc #53 and 22 to see if this is protected enough on the FG door. I did see later on a cutaway sample of how they make up the wood reinforce on the stile. The lock block is 22" long, but only about 3 -1/2" wide so when the holes are drilled there is only about a half inch of solid material left behind.
        The other misc fit and hinge problems were on steel doors, prehung, fullview as in REAR jpg near the flag, or half lites on utility doors. I don't know if they were the higher grade TT but probably, because my suppliers always know I am looking for full quality as much as I can get. I just hate it when they keep trying to steer me to TT.
        You still have retirement funds or stock in TT?
        NickNukeEm | Nov 06, 2004 11:11pm | #8
        Bob, here along the coastline we have shifted over to almost exclusively FG doors simply due to the steel ones rotting out so quickly.  You can (re)prme and paint, and paint and paint and paint, but it's only a matter of time for a steel door in an exposed location; and most HOs won't maintain the painting schedule to prevent it from happening anyway.  The only steel doors that have a chance are those that are protected from the elements.
        You are pretty adamant in recommending against FG, and I'm just curious as to why.  Might be something I should know about when it comes time to recommend a door.
        1. gdavis62 | Nov 07, 2004 05:29am | #13
          The fiberglass doors are just too flexible for me.
          1. Piffin | Nov 07, 2004 07:19am | #14
            That's my point on that FG one.
            user-2409187 | Jun 24, 2017 01:50pm | #42
            What??
              "The fiberglass doors are just too flexible for me. "
            Fiberglass is a skin (not a structural element) that wraps the frame and its components. Whether the door is fiberglass or steel skinned should have no effect on the door's flexibility!  The assembly (frame) is pretty much the same for each door. The obvious advantage of fiberglass is that it does not rust. Smooth fiberglass holds paint well PROVIDED it has been properly cleaned.
            Door installation is like tuning a piano. It requires skill. Everything has to lie in the same plane, else the door won't seal out the air properly. All reveals must be equal. Check your diagonals. A long screw is always installed in the upper hinge. It must penetrate the stud well because it must withstand the "pull" the door's weight places on the upper hinge.
            All my installations have a long screws on the strike side as well. I take off the weather stripping, pre-drill, shim, and place three sturdy screws on that side of the jamb. They are hidden from view once the w-strip is re-installed. All my doors are hung so that they can be tended to should the need ever arise.
            Don't ever depend on brick molding alone to hold the door in place. The finish nails that hold the b-molding to the frame are the weak link in the structure...so...beef up with screws (as described above). Door installation is fun work...a pain in the butt if not done correctly.
      3. xMikeSmith | Nov 06, 2004 11:36pm | #9
        gene...we've used Peachtree, Stanley, Therma-Tru, Marvin, and Andersen
        most of our entry doors are Therma-Tru.. never had any complaints with them..
         on our own house ( 1985 ) all of the doors are PeachTree.. very satisfied with them..
         we've been using more of the FiberClassic  and SmoothStar doors lately.. again ,no complaints.. is there something i should be looking for ?
        1. homewrite | Nov 07, 2004 12:08am | #10
          I'll add to this discussion with a quick comment about Stanley doors. Here in Houston, Texas the jambs do not hold up to the weather.  The jamb stock is made out of finger-jointed white pine and it starts to rot where it meets the aluminum threshold after a few years of service. The doors give good service, but the whole unit becomes worthless if jamb material looses its structural integrity. Local suppliers sell some jamb stock called Jamb Saver. It is rot-resistant enginnered wood on the bottom 12 inches joined to regular wood for the balance of its length. My experience with this product has been favorable; although, I often have to build my own jambs because many of the prehung doors do not come with this material. Stanley should use this product to fabricate its prehung units. Have any of you had similar experience with Stanley doors?
            user-2409187 | Jun 24, 2017 06:49pm | #43
            TTru rot-free jamb/sill interface
             Check this link  http://www.enduraproducts.com/product-overview/framesaver/index.aspx for a rot-free TT jamb/sill interface. I order all my doors with this feature. I have no difficulty convincing my clients that this is the way to go.
            I can well imagine that the intensity of Huston's summer sun punishes the finger-jointed, primed-and-painted door frame. No matter the door brand, finger-joint stock does not hold up well when exposure to the sun. Pella makes door frames that are aluminum clad...and you pay accordingly.
            As others have noted, assembly of TT (name your fav brand) doors/frames is done by a non TT factory. I suppose much of the process is automated. I too find that hinge screws are poorly installed...crooked...not fully seated. And sill sealant is not cleaned off. However, these are minor inconveniences relative to the quality of the product. The business has become very competitive. There are less well-known companies that make excellent doors.
        2. gdavis62 | Nov 08, 2004 01:08am | #23
          Who builds yours, Brosco or Huttig?  I always thought that the guys in the Huttig door shop in Newington, CT did a great job.  I have seen what Brosco brings in here to Gregory Supply, and the quality is variable.
          For a stain job on a grained FiberClassis or ClassicCraft, don't use anything but the Therma-Tru kit product.  They worked hard to get it right, and they did.  The combination of the stain and the waterborne clearcoat outperforms anything else by a factor of two or three.
          I always thought the adjustable "security" strike was a piece of crap, and insisted I got a plain prep on the strike jamb.  Then I would outfit the unit with either the strike that comes with the hardware (Schlage A or Emtek for me, unless I am going Baldwin), or use one of Timely's adjustable ones, shown here.
          1. xMikeSmith | Nov 08, 2004 02:06am | #25
            i'm pretty sure Huttig builds the TT..
             Brosco now has all of the Andersen.. which used to be shared with Cleary ( out of CT)
            interesting insights on the door industry from you...
             i 've always been impressed with the And. Frenchwood product.. and in terms of price , it's a lot easier on the budget than the Marvin doors
            worst product  ( to me ) is the Weathershield doors and windows.. i've lost more money trying to deal with them... that i just gave up.. i now refuse to do any weathershield work for my prospective customers.. i just tell them , i will replace the weathershield witha  different mfr.
            can't remember who the dist is for Weathershield.. but they do make a bad product  worse.. ( could it be Huttig ? )Mike Smith   Rhode Island : Design / Build / Repair / Restore
          2. Piffin | Nov 08, 2004 02:11am | #27
            Mine come out of the Brosco shop.
          3. jrnbj | Nov 16, 2004 05:53am | #37
            Hi, never seen an adjustable strike before....who stocks them.....
  2. Svenny | Nov 06, 2004 10:17pm | #3
    I have used Therma-Tru doors for close to 20 years and have had no proplems.
    John Svenson, builder,  remodeler,  NE Ohio
  3. Snort | Nov 07, 2004 06:50pm | #15
    I can't count how many Therma Tru doors I've installed, but it's well over a hundred. Both fiberglass and steel. Only one problem with a warped slab on a double door, and the distibutor replaced that without any qualms...I've swapped out a few slabs for stylistic reasons, and was always amazed at how the replacement slabs fit with out any tweaking...
    But, in the last couple of years, the pre-hung frames have become poo. Crappy reveals, tops, bottoms, and sides...hinge screws so crooked, that the hinges can't fully close...hinges not in the mortices...lousy threshold adjustments, and I refuse to set any with a fixed fiberglass thresh...
    and, back to the slabs, 2 weeks ago I hung six TTs with semi-circular lights...all the lights were installed crookedly, not sure if that's the distributor or TT...
    I'd like to find a better door, too<G>
    Don't worry, we can fix that later!
    1. gdavis62 | Nov 07, 2004 07:27pm | #16
      That plastic threshold component is extruded PVC, not fiberglass.
      1. dIrishInMe | Nov 07, 2004 08:34pm | #17
        Didn't see this mentioned above, maybe it was, but it is important to realize that generally ThermaTru only manufactures the door slabs.  A local door shop builds the prehung unit consisting of slab, jambs, threshold, hinges, etc.  We have discussed this here before, and we had comments from a apparently extremely knowledgeable individual - can't remember his name.  So, the TT prehung doors Piffin gets may, in fact, be very different and inferior to the doors that Mike Smith gets only a few hundred miles away.  Either that, or Piffin's installs were just defective because of these sheet rock screws he used... ;-)   Matt
        1. gdavis62 | Nov 07, 2004 08:50pm | #18
          TT makes all their slabs, all their doorlites, and most of their sill/thresholds.
          They used to make their own weatherstrip, when it was the dual-durometer extruded bulb type.  If it is a jacketed foam product now, it comes from Schlegel.
          Hinges, if they bear the Therma-Tru stamp, are Chinese, and so are the screws that are used with them.
          Their distributors are the ones that install lites and build the prehung units, so any quality problems with door assemblies that are assembly-related are the fault of the door shop, not Therma-Tru.
          They are a business unit of Fortune Brands, now, and Fortune Brands companies include Aristokraft and Diamond cabinets, Foot-Joy athletic footwear and Cobra golf clubs, and Jim Beam.  Interesting mix.
          I spent thirteen great years with them when the biz was privately owned, but left after the owners sold it.  The coolest part of being there when the owners decided to sell was what we in management came to call the "Andersen pout."  Andersen was approached as a potential buyer-suitor, and when the books were opened as part of the due diligence, the boys from Bayport were in shock and awe when they found out Therma-Tru booked more profit than them, year in and year out.  Not more gross sales dollars, but profit.  It's what counts.
          1. dIrishInMe | Nov 07, 2004 09:11pm | #19
            Not necessarily meaning to argue with you since it sounds like we are basically saying the same thing, but I just walked over to my TT garage door and looked clostly at the hindges (for the first time).  They had stamped in them "Therma-Tru" and "made in usa".  Vinatge 1999 - maybe that was before the sellout?  Then checked 3 other doors in the house (still 1999) and 2 showed the same thing - but the front door was missing the "made in USA" stamp...  Hummm.
          2. gdavis62 | Nov 08, 2004 12:15am | #21
            Lawrence Brothers made the TT hinges for them up through about '98, then the offshore sourcing began.  The distribution world is a large universe, and many of the wholesalers have (or had) out-of-balance inventories.  Thus, your USA hinges.
            TT's manufacturing of all door lites and most of the sills, takes place in Mexico, at a wholly-owned subsidiary, in a plant employing almost 2,000 workers, mostly women.  We used to remark that the Matamoros workers, who live in houses that look like reclaimed piano crates, and who make ridiculous wages, come to work each day better dressed than the typical stateside TT plant worker dresses on Sunday.
          3. Snort | Nov 07, 2004 09:15pm | #20
            I'll have to take your word about the PVC. I've had occasion to drill thru a few, sure seemed like fiberglass. My point was: what's the point of a non-adjustable threshold? And while on the Therma-Tru threshold subject, I've gotten several lately, which have developed rusty adjusting screws. It's taken over a year to get one replacement, and on that one, the screws didn't line up with the threaded inserts!
          4. gdavis62 | Nov 08, 2004 12:44am | #22
            Ah, another believer in the value of the adjustable sill.  You must set doors in openings where the floors fall out from under the walls.  I hate it when that happens ;-)
            I don't use them now, but when I worked there, used some Therma-Tru steel and fiberglass doors on projects.  Couldn't beat the deal.  Take it from an insider who had plenty of experience with doors and their sills . . .  those fixed ones work fine.  They are all I ever got in my TT prehangs.  But then again, I had a little say-so in the quality of the units I got.  I could go out in the prehang shop of the plant, and either watch them get built, or check them out after, before ship-out.  I can recall some getting scrapped out and remade, for some reaon or another.
            Take for example the absolute king of weatherproof performance in the hinged patio door product class . . . the Anderson Frenchwood hinged patio door.  I have used a few of these, and in nasty exposure situations, have never ever seen a leaker.  No adjustment in that Anderson sill.
            And that is the point I used to make in discussing the merits of the adjustable sill with others in the business.  If it is so important, why do the big window people not use them in their hinged patio door product lines?  If any hinged door needs to be leakproof, it is a hinged patio door.  But adjustable sills are not used by Andersen, Pella, Marvin, nor by many others.
            I prefer the look of a one-piece milled hardwood sill, and a door outfitted with a dual-fin sweep bottom gasket sold by Resource Conservation Technologies.  It is extruded siliconized rubber, and outperforms those cheapies you see stapled onto the bottom of most all those units you see coming to the lumberyards from the distributor door shops.
          5. Piffin | Nov 08, 2004 02:07am | #26
            ah, Diamond cabinets have downhill fast in the last several years also. Hope that Fortune doesn't ruin Jim beam too. I need the help when I'm crying over the other poor quality products!
        2. Piffin | Nov 08, 2004 02:03am | #24
          You must not have read this thread very well yet. Those points were made twice so far above and the well known individual with TT experience is Bob Dylan who used to be Mr Micro, who used to be...anyway, he used to work for them and knows his doors pretty well.
          1. dIrishInMe | Nov 08, 2004 02:18am | #28
            OH - OK, thanks.
            Matt
          2. gdavis62 | Nov 08, 2004 02:31am | #30
            Since the election, I am thinking of changing my Breaktime name, again.  Many of the big names in the FrankenKerry camp may have moved offshore already.  Redford may be going to Ireland, Whoopi's prob'ly goin' somewhere, and Dylan may be headed for South Africa or someplace.  Michael Moore is rumored to have taken a bath, is clean shaven, and has lost 40 already on the South Beach.  He can stay, cause we won't recognize him.
            That's it!  Michael Moore!  Has a cachet, don't you think?
          3. Piffin | Nov 08, 2004 03:10am | #31
            brother to Micro-Moore, LOL
    user-2409187 | Jun 21, 2017 08:18pm | #40
    40+ years installing TTrue
    I've been installing TTrue for the last 40 years (I'm 67 going on 30...so there :) I can say flatly and without hesitation that I have never had a complaint. Replacement parts are easy to get.  In my estimation the lion's share of complaints about entry doors can be traced to faulty installations.
    OK...so I do have one complaint...and it is not native to TTrue doors alone. It's this: the molding (PVC?) around the glass will not receive paint or stain  very well.
    On rare occasions I install Pella doors...but you said you did not want to pay a large $um. Stick with TTrue...and install them carefully.
