wheelchair ramp
casnshs | Posted in General Discussion on July 13, 2006 02:09am
I need to build a wheelchair ramp at my wife’s grandparents any guidelines on the recommended width and slope on the ramp for ease of access.
Also what is best to use on the deck of the ramp? some of the composites I have looked at had a rough enough surface to act as a tread or should I just use 5/4 decking?
Thanks, Chris
  1. Jer | Jul 13, 2006 02:14pm | #1
    Gotta be 48" wide and a 1 pitch. (1" rise on 12" run).  I don't know how  high you have to go, but you may have to build a landing.  I've used 5/4 decking with the epoxy sand strips or paint that they use around pools.
    1. casnshs | Jul 13, 2006 02:20pm | #2
      okay that sounds fine I am only about 2' off of the ground so a landing may be used depending on how far they want it to stick out
        PeteDraganic | Jul 13, 2006 03:36pm | #3
        2' off the ground means you'll need 24 feet of finsihed ramp length in order to be code compliant.
        The difference between stupidity and genius is that genius has its limits. -Albert Einstein
        http://www.peteforgovernor.com
        1. Piffin | Jul 13, 2006 11:30pm | #5
          and 1/12 is the minimum. I've build one at 1/20 that was nice and comfortable.
          1. Jer | Jul 14, 2006 02:36am | #7
            You're right, I forgot to mention that 1/12 is minimum.  1/20!?  That 's a looooong ramp.
          2. Piffin | Jul 14, 2006 12:48pm | #9
            1/20 waas the pitch. The ramp was more like 26' longIt was around the back side of the house. You drive in to the end of the house ands wheelchair up the ramp to the porch on the other end of the house, then in through sliding glass door. Kept the ramp out of view, butr very easy access. Had I made it only 1/12, you would have exited the car, then down slightly to hit the ramp, then up a steeper ramp.. This one brought tjhe ramp close to the car, which was good in mud season. Surface drainage went opposite direction of ramp
    draftguy | Jul 13, 2006 06:37pm | #4
    site for ADA info
    http://www.access-board.gov/adaag/html/adaag.htm#4.8
  3. WayneL5 | Jul 14, 2006 12:45am | #6
    Piffin's right on the money.  1:12 is considered maximum slope with 1:20 preferred.  The website in the prior post will have all the recommendations you need with regard to dimensions.
    The slope somewhat depends on the use.  If the client will be pushed up by an able-bodied person then a steeper slope may be fine, but if the client wheels up or is pushed up by an older person then a shallower slope is needed.  Space and money limits that, of course.
    As for decking, wood tends to get slippery when wet, especially if in a damp climate or a shady location where algae can grow.  Some people use roll asphalt roofing (granulated) as a runner.
    user-14544 | Jul 14, 2006 07:16am | #8
    here's one I did for a rollercoaster ride at the local zoo...
    (now why a kid in a wheelchair would ever ride a roller coaster????)
    I did mine 1/16 to get it to land just right...used a composite 5/4 decking that had a "textured groove" machined into it...Ultra Deck maybe?? Anywho, seemed to work out ok.
    knowledge without experience is just information.... Mark Twain
    Politicians, like diapers, need to be changed often...and for the same reason.  (bumber sticker)
    http://www.cobrajem.com
    1. Junkman001 | Jul 14, 2006 06:39pm | #10
      Don't you have requirements for continuous graspable handrail?
      Mike
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
