When did drywall become structural?
nater | Posted in General Discussion on May 18, 2007 04:20am
Found this article online about modular green building
What got me curious was these lines: Modular houses are stronger than traditional ones, said Don Diamond, an electrician with St. Louis-based Diamond Electric, partly because the drywall is attached much better.
“In a modular home, the drywall is glued and screwed. Once you do that, you can pick the house up from one end with a crane, and the entire structure will come up in one piece,” Diamond said. “In plastered homes, stuff moves around and settles in pieces. It is not as well integrated.” http://www.stltoday.com/stltoday/business/stories.nsf/story/C416076B5B3E8C1F862572DD000C601B?OpenDocument
    JDRHI | May 18, 2007 04:38pm | #1
    He's an electrician.....whadya expect?
    If it were up to them and plumbers, we'd do away with those pesky framing members altogether.
    J. D. Reynolds
    Home Improvements
    1. Hudson Valley Carpenter | May 18, 2007 07:30pm | #5
      <<He's an electrician.....whadya expect?
      If it were up to them and plumbers, we'd do away with those pesky framing members altogether.>>
      LOL.  Yep, if it up to them, they'd go in first and we'd frame around their stuff, later.
        JDRHI | May 18, 2007 07:39pm | #6
        I've actually had plumbers suggest that.
        Not always a bad idea after you see what some of them do with a Sawzall.
        J. D. ReynoldsHome Improvements
        1. DanH | May 18, 2007 07:46pm | #7
          Yeah, and then the framers could cut out the pipes that are in the way.
        2. Hudson Valley Carpenter | May 18, 2007 08:20pm | #10
          Boy, ain't that the truth!  In the end, it would be better for all if their floor drains...showers, tubs and toilets...were always indicated on the framer's print.
          Edited 5/19/2007 8:33 am ET by Hudson Valley Carpenter
      2. mike_maines | May 19, 2007 12:06am | #11
        You might be on to something there....
    2. Shacko | May 18, 2007 08:00pm | #9
      Being a plumber, I resemble that remark >sic
    BossHog | May 18, 2007 04:39pm | #2
    Drywall does have a small amount of shear value if fastened well.
    But I doubt that has anything to do with the strength of modular homes...
    The California state bird is the middle finger. [Jay Leno]
    Huck | May 18, 2007 04:57pm | #3
    Its been a long time, but I've seen the dryall nailing schedule spec'd for shear value.  Its usually like a double-nailing pattern, with the nails about 1" apart.  I thought it was a typo, but the archie assured me that it was legit.  Never understood how anyone could figure drywall for shear.  Maybe an engineer will jump in and explain it.
    "I needed a drink, I needed a lot of life insurance, I needed a vacation, I needed a home in the country. What I had was a coat, a hat and a gun."
    Raymond Chandler's Philip Marlowe
    1. DanH | May 18, 2007 05:30pm | #4
      Well certainly drywall has shear strength. A bare stud wall can be easily racked, but it would take hundreds if not thousands of pounds of pressure to rack a drywall-sheathed wall, say, 10 feet long. Probably drywall is about equivalent to 1/4" plywood in this regard.Drywall has an advantage of not being especially brittle (less brittle than that 1/4" plywood, eg), so it can add considerably to the strength of a structure in "shock" conditions. However, it is subject to fatigue, and would not provide much strength in a structure subject to frequent flexing.So probably better stuff to have in a tornado vs a hurricane.
    CapnMac | May 18, 2007 07:46pm | #8
    Well, at first blush, the sparky is making an apples and asparagas comparison.
    There's no comparision between drywall and plaster-on-lath; that's two completely different things.
    However, the amount of plasterwork on lath rather than blueboard cannot be that high anymore--which makes it an absurd comparison.
    Now, if our illuminating pontificator would like to demonstrate how 2x3-framed modular competes structurally with 2x6 & 2x4 framing, that might be more interesting.
    But, if the goal were merely strength, galvanized framing with gypsum wall board both sides would be the rule (with a w/p and/or paperless on the exterior surface).
  5. fingersandtoes | May 20, 2007 06:05am | #12
    Drywall became structural when builders stopped providing blocking in closets and began hanging their shelves and bars from it. Drives me nuts.
  6. ruffmike | May 20, 2007 07:12am | #13
    I once had to nail a whole sheetrock wall off 2" on center in Santa Cruz Ca. back in the '70's, for a shearwall to please the inspector. True story!
    Here is a product we use a lot now that is stuctural sheetrock.
    http://www.sureboard.com
    Not fun to hang, and the layout better be good. ; ^ )
                                Mike
    1. dovetail97128 | May 20, 2007 08:34am | #14
      Sheetrock has been used structurally as bracing on the bottom chords of trusses ever since the two were used together. Every residential truss lay out sheet and engineering sheet I have looked at in 35 yrs. calls for rigid ceiling or bracing.
      "Poor is not the person who has too little, but the person who craves more."...Seneca
      1. MisterT | May 20, 2007 08:57pm | #15
        Wall paper is structural...
        not very, but some...
        if you had an intrument sensitve enuf you could measure the strength of paint...I don't Know what I am doing
        But
        I am VERY good at it!!
  7. bobbys | May 20, 2007 10:22pm | #16
    my boys friend was building a house, They showed me the wall where the taller ceiling meets the room with no high ceiling, They said the BI made them double nail it for sheer, i had never heard of this before, seems the more nails would even tear the paper more??? maybe if this is the case i can use it when i rip off a roof, Instead of putting down plywood over the skip sheathing i can use SR;)
      Huck | May 20, 2007 10:59pm | #17
      Surprisingly, it is not uncommon to see drywall used as an exterior paneling under dryvit-type finishes, on commercial metal-stud framed projects.  It is a specialized product made for that application - but I don't think I've ever seen it used in an application where it might get walked on!"I needed a drink, I needed a lot of life insurance, I needed a vacation, I needed a home in the country. What I had was a coat, a hat and a gun."
      1. ruffmike | May 21, 2007 01:19am | #18
        We see a lot of Densdeck on commercial roofs.
        http://www.gp.com/build/product.aspx?pid=4664
        But I guess I wouldn't want it on my backyard deck. ; ^ )
        Don't be surprised though, with gypsum the most common element on earth and one of the cheapest they will try to use it anywhere possible.                            Mike
