When to fix DW mistakes
tab1 | Posted in General Discussion on March 9, 2009 12:53pm
I’ve put up new wall and ceiling DW and just finished a coat of primer. Not surprisingly found a few small spots here and there that needed a bit more compound.
Is now–as opposed to after a top coat–the appropriate time to fix them? And should I just use more (lightweight) compound, or switch to something like spackling?
Thanks.
  1. KenHill3 | Mar 09, 2009 01:05am | #1
    Keep on mudding, now's the time. After primer is always a good time to help catch imperfections. Don't forget to re-primer or your mud add-ons will telegraph through to the finish paint.
    Edited 3/8/2009 6:07 pm by kenhill3
    1. calvin | Mar 09, 2009 01:17am | #3
      Finish coat should probably be with whatever you finished with b/4.  If it's a two coat operation-you should use Ltwt. 20 and bambambam, get it done.  Again, final coat with your previous finish.A Great Place for Information, Comraderie, and a Sucker Punch.
      http://www.quittintime.com/
  2. DonCanDo | Mar 09, 2009 01:15am | #2
    Yes, now is the time to touch-up the walls.  If you wait until after the top coat, you will need to re-paint the entire wall again otherwise you will see the repairs.  Prime any repairs before final painting.
    Lightweight compound will work fine.  I'm not sure what "spackling" is.  There are a lot of products that are called "spackling compounds".  Joint compound is one such product.  There's even a product actually called "spackle", but there's really only one since it's a proprietary name sort of like "scotch tape".  That would work too.  Do not use lightweight Spackle¯ or Dap's Lightweight Spackling.
  3. MSA1 | Mar 09, 2009 02:33am | #4
    Even if the HO wants to paint I will sometimes prime just for this reason. The primer is great for finding "sins" and the best time to repair them.
    I also use a 1/2" nap roller on new drywall to help add a little texture to the drywall.
  4. AitchKay | Mar 09, 2009 03:04am | #5
    Primer is good, because it removes the color differential and lets you really see.
    Come back in the evening, and walk around with a fairly-low-wattage bulb in your hand. Hold it close to the wall/ ceiling, and you'll see EVERYTHING.
    Circle the bad spots, or draw a line along them, depending on how they manifest themselves, then come back and spackle with hot mud, e.g. E-Z Sand.
    Then spot-prime, and you're ready to paint.
    AitchKay
  5. DanH | Mar 09, 2009 03:28am | #6
    I'm sorry, but once she's become your DW it's too late to fix it.
    (What? He meant "drywall"? Never mind.)
