when to paint stucco?
robdog | Posted in Construction Techniques on July 11, 2008 05:58am
i am finishing up the stucco on a house and am trying to figure out when to paint it….3 coats of cementatious mortar over lathe over tyvek……should i wait a while to let it cure or go ahead and spray now?  if i wait, it is going to mess up my job schedule, but i don’t want to rush and do the wrong thing………
thanks y’all
  1. rlrefalo | Jul 11, 2008 06:22am | #1
    There are elastomeric paints to conceal the inevitable shrinkage cracking, follow the guidelines of the manufacturer. Sorry, can't recall the manufacturer now.
  2. brucet9 | Jul 11, 2008 06:38am | #2
    I'm curious as to why you are doing new stucco with the idea of painting it instead of using colorants in the final color coat?
    Stucco takes 28 days to cure (see brochure at http://www.lahabrastucco.com/PDF/ext_stucco_color_coat.pdf)
    You didn't fill out your profile, so I can't tell what area you are from, but if the air is dry where you are, you should spray the set stucco with the garden hose frequently to aid in getting a full cure. (see paragraph c3 in the above linked document.)
    BruceT
  3. peteshlagor | Jul 11, 2008 07:04am | #3
    One does NOT paint real stucco.  One fog coats it.
    1. robdog | Jul 11, 2008 04:19pm | #4
      hey, thanks y'all.....
      i would have loved to have mixed in the color, but the archy convinced the clients that the color would be 'splotchy' and not match their paint chip exactly....blah,blah
      what is a fog coat? and don't answer 'one of those blue double breasted navy deals'!
      yes, i'm going to use elasometric paint....how long to wait?
      thanks again!
      1. peteshlagor | Jul 11, 2008 04:43pm | #6
        http://www.lahabrastucco.com/stucco_products/fog_coat.htm
        Elastomeric paint seals up the breathability of real stucco.  Some believe it shortens the lifespan of the siding and retains any moisture to result in mold damage.
        But, hey, it's your house!  Not mine.
          popawheelie | Jul 11, 2008 04:52pm | #7
           Elastomeric paints are used when old stucco is on it's last leg.
          I grew up in L A and there are lots of old houses hanging together with paint.
          If you need to paint it I'd do a minimum coating to get a uniform color.
          The La Habra coating sounds right. I've been to La Habra.
          Stucco is supposed to breath.
          Edited 7/11/2008 9:55 am ET by popawheelie
        2. gfretwell | Jul 11, 2008 05:02pm | #8
          Stucco is usually over block in Florida, you want it to seal.
  4. gfretwell | Jul 11, 2008 04:38pm | #5
    The rule of thumb in SW Fla is minimum one week. It has to do with the pH of the curing mud from what I understand
Grout-Free Shower Panels
