Just had an Anderson 400 Series window installed and I’m trimming the outside. Where should I be caulking? Should I caulk between the trim and the window? Does the bottom trim piece get caulked on the bottom?
Thanks for any info in advance
After sealing the side and top nailing flanges to the building with Vycor (or similar), I run a healthy bead of clear silicone along the sides and top before installing trim. No caulk on the bottom.
I'd look at Anderson's website and see what they have to say. The window has been flashed presumably, don't caulk the bottom of the sill or the bottom of the head casing. bedding the legs in runs of vertical sealant under both edges is good, just don't run sealant horizontally under the legs. Think about not creating any water traps if/when water gets back there.
What's on the exterior? How are you trimming it?
Much luck finding your answer-
"I wanna be a race car passenger. You know, the guy that bugs the driver. Say, man, can I stick my feet out the window? Do we have to keep going in circles? Mind if I turn on the radio? Boy, you really like Tide."
The installation guide is pretty specific in caulking criteria. Check yours.
The last bunch of 400s I put in required the flange be flashed over, then caulk between window and trim. The bottom is left as is so H2O can escape. Gap between trim and window is 1/4".
Link is for installation guide for 400 double-hung.
http://www.andersenwindows.com/servlet/Satellite?blobcol=urldata&blobheader=application%2FpdfContent-Disposition%3A+inline%3B+filename%3D0005134.pdf%3B&blobkey=id&blobnocache=false&blobtable=MungoBlobs&blobwhere=1186928299650&ssbinary=true
I'm of the opinion that the caulk is not as important as proper flshing w/vicor and flex wrap at the corners. The caulk is going to fail in short order anyway, and I've read some place, I don't remember where, that siding holds paint better at the junction of trim and clapboards when not caulked, presumably because it dries out easier after getting wet. Since I read that a few years ago, I've been observing a lot of siding for evidence of that, and I thinks it's true.
As others say, no caulk at the bottom. Water is going to get in eventually, it has to be able to drain out.
Steve
when you say "trimming the outside" .. that means a lot of different things
a 400 has narrow jambs & head, and a pretty skimpy sill, when we trim them we would likely use a false sill ripped & rabbeted fro a 2x4 piece of trex
the side casing would be 5/3 x 4 ... adn the head casing would be 5/4 x 6
you can't paint air.. so we caulk between the casing and the jambs
and we caulk between the false sill and the Andersen sill
the false sill has a rabbet that fits over the siding below
the nailing flanges and the Andersen bottom seal are all flashed into the underlayment and siding system
the caulk is not for water protection, it's to give you a paintable surface
most homes just get the window.. no additonal trim.. the siding goes right to the narrow vinyl jambs.. there again.. the caulk is not for water protection .. it's to give a paintable surface
I try not to create air. I cut my siding tight to the trim. If I recall in the past you've advocated leaving 1/8" gap for caulk, no?Steve
steve... short of a glued joint.... you have air
the paint won't fill even that small gap
in the old days , they would putty that gap
today they fill the gap
then they cut in
you can't paint air
you can make a very tight , neat, joint....but you can't paint itMike Smith Rhode Island : Design / Build / Repair / Restore
