Where to nail lap siding?
MichaelW | Posted in Construction Techniques on September 17, 2011 02:37am
Hi,
I am installing cedar lap siding that is 5 1/4 by 1/2″. I have been told that I shold nail the boards high enough so that the next layer up covers the nail heads.but the Western Red Cedar Association http://www.wrcla.org/pdf/WRCLA_Installing_Siding.pdf installation guide says to nail near the bottom of the board, so the nail heads would be exposed. I don’t understand why you would expose the nail heads like that. Does anyone have recommendations or explanations about this?
Thanks.
  1. JimB | Sep 17, 2011 04:26pm | #1
    I always assumed that
    nailing just above the top of the lower piece was intended to hold the siding flat against the wall to prevent cupping and wind up-lift.  Exposure of the nails shouldn't be a problem if the correct nails are used.  Stainless steel produces better results if the siding isn't painted.
  2. DanH | Sep 17, 2011 04:55pm | #2
    I think that 5 1/4 can go either way, but wider siding (especially real wood) needs to be face nailed to prevent curling.  With real wood, though, it's important to place the nail such that it DOES NOT penetrate the top of the course below, so that the wood can shrink and expand cross-grain, and therefore reduce splitting.
    Cedar, in particular, tends to curl more than other species.
  3. edwardh1 | Sep 17, 2011 10:42pm | #3
    for hardie "planks"
    they have 2 nailing specs.
    one is top nail the other is face nail. I think the face nail is good for more wind resistance like 140 mph compared to 120 or so with "blind "/ top  nailing.
    I did not use face nailing (near the bottom edge)  cause it looks really ugly especially if nail rust, and or are driven too deep creating a hole that must then be caulked.
    1. DanH | Sep 17, 2011 11:41pm | #4
      But I believe you'll find that the Hardie specs call for the nail head to remain proud.
        MarkH | Sep 18, 2011 08:26am | #5
        That's so you dont have to caulk all the nails.
        1. DanH | Sep 18, 2011 08:33am | #6
          It's so you don't damage the planks.
            MarkH | Sep 18, 2011 08:35am | #7
            OK Mr. Serious.
          2. edwardh1 | Sep 18, 2011 10:26am | #8
            true!
            But the
            "foreign
            true!
            But the
            "foreign nationals" the condo board hired to install the hardie planks claimed not to know how to adjust the air pressure input on the nail gun gee a big tee handle thing on the comprssor (!!!!????!!!!) so they drove a lot of nails 1/3 way thru the Hardie, then of course messily caulked it.
      2. Hokuto | Sep 19, 2011 12:28am | #9
        The Hardie instructions I currently have permit either "snug" or "flush" driving, with preference for the latter. Anything deeper than flush is to be caulked and an additional nail put in beside it.
