Where will you be when Sharkbite o-ring goes south?
IdahoDon | Posted in Construction Techniques on April 6, 2012 12:30pm
I was just thinking of how many o-rings last as long as soldered copper and I couldn’t think of any – although I’m sure they use a high quality material in the o-ring.  What’s the lifespan of a sharkbite fitting?   On their website it’s never addressed other than referencing standards it meets.
I’ve used them, and probably will again in certain situations, but it’s hard to get excited about buring something in a wall unless it will last as long as the rest of the system.
  1. DanH | Apr 06, 2012 07:31am | #1
    Generally an O-ring only fails when there's motion.
    (In any event, since even an O-ring exposed to gasoline will last 30 years, "where I'll be" is dead, most likely.)
    1. IdahoDon | Apr 08, 2012 07:30pm | #7
      I'm fixing an oring in my truck AC that has lasted since 1985 - I would have liked it if it lasted a while longer!
      1. DanH | Apr 08, 2012 07:43pm | #8
        Yeah, and that O ring in your AC was subjected to enormous vibration stresses, not to mention severe thermal cycling.
        And a water main failure can cost hundreds of thousands of dollars and flood several homes.
  2. florida | Apr 06, 2012 03:40pm | #2
    I'll be in the same place I was when the copper fittings on my duplex went south, or where I was when the polybutylene pipes in another house split, or where i was when the galvanized pipes in my first house sprung pin holes, that is, I'l be replacing pipes. I hope PEX will prove to be more long lasting then the rest but only time will tell. In the meantime I use Sharkbites to make repairs that woul dbe expensive to make otherwise.
  3. rdesigns | Apr 06, 2012 05:04pm | #3
    It's not just sharkbites that rely on O-rings. There's PressFit, Viega and others that rely on the O-ring, and they're being used extensively in commercial applications, and for large diameter piping.
    I've wondered the same thing, but have not found a good answer.
    Mongo | Apr 06, 2012 08:29pm | #4
    Can't do it
    I just can't, with good conscience, bury a sharkbite fitting in a framing cavity. I've only used a few over the years, always exposed in a basement.
    Just one of those things for me.
    1. DanH | Apr 06, 2012 10:58pm | #5
      Of course, keep in mind that the water pipes under your street use rubber gaskets to join them, and have for 75-100 years.
      1. IdahoDon | Apr 08, 2012 07:26pm | #6
        If a water main fails it floods the street - if a client's plumbing fails it hopefully doesn't flood more than one floor!  lol
        Water damage is so expensive to fix that I'm still a believer that not enough is done to protect supply lines.
        Mongo | Apr 09, 2012 12:54am | #9
        that's fine...
        ...since I'm not personally liable for the repair if one fails. lol
    2. DanH | Apr 09, 2012 07:07am | #10
      (But i do share your concern with using a technology that doesn't have a track record.  Standard copper has a roughly 100 year history.  PEX, after several disastrous false starts, has a pretty good track record of 20 years or so.  SharkBites have been around for what?  Five years?  I'm just saying that the O-ring itself is a pretty well-known technology -- probably 75 years -- and is not likely to be the precipitating cause of a failure.  If SharkBites have an Achilles heel it's probably somewhere else.)
