which Caulk/sealant for roof patch
ahneedhelp | Posted in General Discussion on August 12, 2002 04:10am
Hello –
Our roof is due for a replacement, probably next spring as soon as it starts getting hot.
In the meantime, the roof is showing half a dozen nail heads that have popped up through the shingles.
I need to work them back down carefully and seal the spots to get us through the winter.
They were disconvered while I was up there inspecting and clearing the gutters. Inspection of the attic didn’t reveal any signs of leaks after several heavy rains.
Will silicone do the job ?
Is there a roofing specific caulking that works better ?
I also want to dab some around vent stacks and chimney flashings to be ready for snow.
Thanks !
Alan
  1. Piffin | Aug 13, 2002 02:17am | #1
    If you are just trying to get through another year, anything will do.
  2. IronHelix | Aug 13, 2002 02:31am | #2
    I can't say silicone does well with petroleum products..... but there is a product called "Through The Roof" that is very good with asphalt.   Or just plain old plastic roof cement in a can or a caulk tube.
    .........................Iron Helix
  3. tedvan1 | Aug 13, 2002 02:41am | #3
    Go with Henry 208 plastic roof cement . Somehow it will get on you so wear old clothes and bring some rags.
    RichBeckman | Aug 13, 2002 03:00am | #4
    If the "caulk/sealant" is going to be exposed, use butyl rubber. Widely available around here if you are not picky about color. If the "caulk/sealant" is used to cement something down and will be covered by the something, use roof cement.
    You can get roof cement in tubes, but I actually find it neater to take it out of a one gallon can.
    Rich Beckman
    1. ahneedhelp | Aug 13, 2002 04:16am | #5
      Thanks, Folks.
      Went with "Through the Roof" - most expensive of the selection in tubes. It spreads easier then silicone.
