Which Narrow Crown Stapler??
Waters | Posted in Tools for Home Building on December 7, 2008 08:45am
I need a narrow crown stapler.
Want one that will do 1 1/2″ staples–seems more useful.
Bostich?
Hitachi?  New one looks tinny…
Porter Cable?
Rigid has one that looks good?
Max has one that’s 2x the cost of any others???
Votes?
  1. KenHill3 | Dec 07, 2008 10:24pm | #1
    "Porter Cable been very good to me."View Image
  2. webby | Dec 07, 2008 11:07pm | #2
    I bought one of the new Bostitch when they came out. Sx150k or something. A lot of plastic parts.
    It works okay but I have had problems with it misfiring longer staples. Actually it is the second one I have, the first I returned. The trigger valve leaked.
    Webby
    Edited 12/7/2008 3:13 pm ET by webby
  3. inperfectionist | Dec 08, 2008 12:23am | #3
    When I shoot off underlayment I rent an Hitachi from my (excellent) local tool rental store.
    It is not the same gun I see for sale at the local hardware stores though. This baby is really well built, and shoots thousands of staples w/o a single jamb/misfire.
    Harry
    IMERC | Dec 08, 2008 12:30am | #4
    if you can find it....
    a Senco SKS....
    WOW!!! What a Ride!
    1. KenHill3 | Dec 08, 2008 02:47am | #8
      Isn't the SKS like 7/16" wide?
        IMERC | Dec 08, 2008 03:01am | #10
        no... it's narrow crown....
        the M2 is 7/16"...
    cdwalsche | Dec 08, 2008 01:26am | #5
    I HAVE HAD GOOD LUCK  WITH SPOTNAILS 1/4" 4800    UP  1 5/8" STAPLES
  6. stevent1 | Dec 08, 2008 01:47am | #6
    What IMERC said.
    Senco. I own 3.
    Chuck S
    1. vanderpooch | Dec 08, 2008 01:49am | #7
      What Imerc and Steven said...They are around used on Ebay, and here at least, on Craigslist.- KitTechnique is proof of your seriousness. - Wallace Stevens
  7. JMadson | Dec 08, 2008 02:48am | #9
    No to Bostich, only uses Bostich staples. Annoying
  8. HomeSolutions | Dec 08, 2008 03:05am | #11
    I have the Milwaukee,never had it misfire yet and I think I paid around 90.00 dollars for it.Love it very lightweight.
  9. User avater
    Ted W. | Dec 08, 2008 03:59am | #12
    I have the Ridgid and am happy with it. But then, I don't use it a whole lot. Probably 2 boxes of staples in it's lifetime, not counting the one that came with it.
    My humble opinion, unless you're really working the heck out of it, any of the major brands will do the job. However, you said 1 1/2" staples, but I think the ridgid only goes to 1-1/4". I could be wrong, but I think that's the case.
    See my work at TedsCarpentry.com
    Buy Cheap Tools! BuildersTools.net
    If you haven't already done so, please update your profile. Since many issues are dependant on the region in which you work, we often look at your profile to see where you are writing from.
    1. JMadson | Dec 08, 2008 04:05am | #13
      Rigid 150FSA goes up to 1.5" staples, I like it too.
        Ted W. | Dec 08, 2008 04:34am | #19
        Thanks, now I don't have to remember to check mine at work tomorrow. =)
        What I especially like about it (and the angle finisher) is the belt hook, comes in real handy.See my work at TedsCarpentry.comBuy Cheap Tools! BuildersTools.net
        1. JMadson | Dec 08, 2008 04:39am | #20
          Uses the PC staples, which the Bostich does not.
          The belt hook scares me, I really don't want a stapler hanging that close to something that really shouldn't be stapled.
            Ted W. | Dec 08, 2008 04:48am | #21
            Heck, tuck the nailer between me legs when I need both hands free. Long as I know which way it's pointing. That's actually easier than fumbling with the hook. But climbing up a ladder or walking with hands full, that hook comes in handy then.
            tbh, I've always felt that nailers and staplers should have a safety switch. See my work at TedsCarpentry.comBuy Cheap Tools! BuildersTools.net
          2. JMadson | Dec 08, 2008 05:02am | #22
            Business idea for someone...
            Add an air cutoff between the hose and the gun. Something small and easy to use. Just a little twist or a flip and the gun has no air.
            Ted W. | Dec 08, 2008 05:08am | #23
            I was thinking a trigger lock, but cut off the air is better yet. Certainly simpler to do.See my work at TedsCarpentry.comBuy Cheap Tools! BuildersTools.net
            Sphere | Dec 08, 2008 02:59pm | #26
            Could probably just use a 1/4 turn shut off valve.
            I an inline regulater with the ends to just attach quickly for my critter type sprayer, and a small touch up gun, it saves trips to the comp or water separater for minor psi adjustments.
            Just a turn of the knob and pressure is off, BUT a gun still has ONE shot of air in the passages..
            Edited 12/8/2008 7:00 am ET by Sphere
          5. BUIC | Dec 08, 2008 05:27pm | #27
              My Makita 18 ga. has a trigger lock.  A little lever to flip a 1/4 turn near the trigger.
              Very safe and convenient.  I've always wondered why more nailers don't have one...buic
      IMERC | Dec 08, 2008 04:06am | #14
      the SKS does 5/8 thru 1-1/2"....
      1. Waters | Dec 08, 2008 04:15am | #16
        Can't find no 'SKS' 1/4" crown unit.
        I find lots of SNS or SKS construction staplers like I already have--7/16" crown.
        Is this a discontinued type o' model?
          IMERC | Dec 08, 2008 04:34am | #18
          dunno...
          seems to be a model change....
          http://www.senco.com/con_rem/ViewTool.aspx?toolid=39
  10. arcflash | Dec 08, 2008 04:13am | #15
    I am surprised about the Bostitch. Everything I own by bostitch is top notch. I have the 1" stapler from them, and I like it.
    1. KenHill3 | Dec 08, 2008 04:15am | #17
      What are folks using 1" staplers for these days?
      1. arcflash | Dec 08, 2008 05:15am | #24
        I use it for some exterior flashings, but galvinization is an issue sometimes. Mostly for drywall cornerbead. A 1 1/2'' might be better, but I've been using the 1" for awhile and haven't had any problems yet. Some people use them for cabinet backs, but I haven't done any cabinetry (yet). Great for 1/4" Luan underlayment or soffits.
  11. oceanstatebuilderinc | Dec 08, 2008 07:06am | #25
    I love the Hitachi. I have had both of  mine for about 5 years and they are still working like champs.
  12. rasconc | Dec 11, 2008 07:27am | #28
    I got one of these when Amazon had them for $40.  It was absolutely new.  I love it.  No longer avail, but you probably can find on ebay.
    Factory-Reconditioned Hitachi N3804AB2R 18 Gauge Stapler
    For those who have fought for it Freedom has a flavor the protected will never know.
