Whistling shower
| Posted in General Discussion on November 1, 2004 04:06am
Does anyone have any ideas about what’s causing my shower to emit a high pitched whistle? This is a new sound from a shower that has worked fine until now. It is a shower over a tub). Thanks. Bob
    BossHog | Nov 01, 2004 04:20pm | #1
    Maybe it doesn't know the words?
    (Sorry - Couldn't resist)
    If they fear you, they will respect you. If they love you, they might respect you. But if they don't fear you, they'll never love you or respect you and they don't have to! [Richard Nixon]
    1. DanH | Nov 01, 2004 09:54pm | #7
      No, that makes it hum, not whistle.
      Obvously the shower has a thing for Bob!! ;)
    IMERC | Nov 01, 2004 05:15pm | #2
    Valve not open/ing or calicified shower head... High pressue thru a restrictive shower head
    But Boss seems to hit it right on the head...
    WOW!!!   What a Ride!
    1. BobnTracy | Nov 01, 2004 06:02pm | #4
      Thanks for the help.
      Bob and Tracy
    GoldenWreckedAngle | Nov 01, 2004 05:41pm | #3
    Have you or your wife been working out?
    Kevin Halliburton
    And with that, the great emporer Oz gently floated away on a curtain of hot air, laughing at the unfortunate ignorance of little people beneath him. But under his breath he cursed that stupid little dog...
    IMERC | Nov 01, 2004 06:10pm | #5
    worn washer on the valve stem may be fluttering / resonating....
    WOW!!!   What a Ride!
  5. ed2 | Nov 01, 2004 08:02pm | #6
    u don't say if it's an older faucet set w shower diverter, or a newer anti-scald valve
    don't know about the anti-scalds, but older faucet sets will shriek, whistle, rumble w bad packing on end of faucet stem
  6. DanH | Nov 01, 2004 09:58pm | #8
    First off, determine if the sound seems to originate in the shower head or the control. If it's in the shower head, remove the head and soak it in full-strength vinegar overnight. If it's the control, and a single-handle unit, just replace the cartridge.
    Another possibility is that the valve in the tub spout is whistling. Simplest fix there, if a vinegar soak doesn't fix it, is to replace it.
  7. WayneL5 | Nov 02, 2004 12:47am | #9
    Ditto the vinegar soak.  Dismantle as much as you can and use an old toothbrush where needed.  Use a small wire to poke holes clean.
FHB Podcast Segment: Patching Drywall Near a Shower
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
