White powder insulation
pugetcove | Posted in General Discussion on August 11, 2008 01:07am
I am remodeling a house in the Seattle area that was built before 1950.
When we were removing the lath and plaster we found a white very fine powder insulation in the attic and sloped cielings. There is a layer of brown paper under it and the powder is about 2″ thick.
I have had an asbestos survey done, with no asbestos found in the powder.
Does anyone have any idea what this stuff is.
    Sphere | Aug 11, 2008 01:18am | #1
    Coke dealers house?
    Might be a  form of vermiculite or pearlite.
    You gonna play that thing?
    http://www.youtube.com/watch?v=32Ln-SpJsy0
    1. pugetcove | Aug 11, 2008 01:21am | #2
      no one is willing to snort the stuff, and its to fine for vemiculite or perlite, this is more the consistency of flour
        Sphere | Aug 11, 2008 01:28am | #3
        Maybe a fire retardent or insect something?  maybe a bad foam job gone past it's useful life.Spheramid Enterprises Architectural Woodworks
      2. Chucky | Aug 11, 2008 04:44am | #6
        perlite is available in powder form.  Perlite microspheres are mainly used as a filler but if someone had some bags of it lying around....
        Who knows, maybe the previous owner worked in a perlite factory and got some for free.
        check out http://www.perlite.org/
        1. pugetcove | Aug 11, 2008 05:06am | #7
          lets say it is perlite - got any ideas on how to get it out
            IMERC | Aug 11, 2008 05:16am | #8
            vacuum...
          2. pugetcove | Aug 11, 2008 05:21am | #10
            tried it - plugs up immeaditaly
            also tried dust collection system - plugs up
          3. Piffin | Aug 11, 2008 07:11am | #12
            commercial vac.A lot of insulators do it for you.
          4. Novy | Aug 11, 2008 07:37am | #14
            Why do you always insist on being straightforward and addressing the point ?
            To the OP get a real drywall vacumn and it will work.
            On a hill by the harbour
          5. pugetcove | Aug 11, 2008 07:43am | #15
            whats a real drywall vacuum
          6. Novy | Aug 11, 2008 07:50am | #16
            I have a Loveless.
            http://www.homehealthsafety.net/servlet/the-120/LOVELESS-16004Q-DRYWALL-DUSTLESS/Detail
          7. User avater
            IMERC | Aug 11, 2008 03:14pm | #17
            habit...
          8. Chucky | Aug 11, 2008 05:20am | #9
            nope...and if i didn't know what it was, i wouldn't try...especially a powder.  did you test for asbestos only or do you have a complete composition analysis ?  Maybe the Perlite Institute has a simple test for you and removal recommendations.
          9. pugetcove | Aug 11, 2008 05:23am | #11
            elemental analysis  should be complete tomorrow
          10. atrident | Aug 11, 2008 07:14am | #13
              I vote for gypsum.
  2. Chucky | Aug 11, 2008 02:57am | #4
    I did a little googling with words "wall insulation powder" and the only thing i could find is this link:
    http://www.chemyq.com/patentfmen/pt23/225609_E8085.htm
    The patent appears to be from 1995 (well after 1950).  Don't know the color.  Also don't know it was a commercial product used for walls and roofs as stated in the patent information.   The materials listed might give you or someone else a clue as to what it might be.
    Text from article:
        The present invention relates to a building material-adiabatic heat-insulating roofing and walling powder material. It is made up by proportioning flyash, expanded pearlite, slaked lime, diatomite, gypsum, short rock-wool, cement, calcium ligninsulfonate and binding agent, and uniformly mixing them. ADVANTAGE-. It is low in production cost, good in adiabatic heat-insulating, sound-insulating and fire-proofing properties, simple in preparation process, and light in volume-weight. Besides, it doesn't effloresce or scale or deform by hygroscopic absorption, and has no carcinogenic substance-asbestos.
    1. pugetcove | Aug 11, 2008 03:25am | #5
      thanks for looking - I've done quite a bit of searching and come empty. My asbestos surveyor, the architect, the home inspector and me (20 years remodeling and new construction) have never seen anything like this.
      I am wondering if it wasn' a solid when installed and has decomposed, because I dont see how it could have been installed in its present state, it is to billowly and fine to be handled or blown or I dont know what.
  3. centralpnw | Mar 31, 2019 11:46pm | #18
    This thread has been dead for over a decade, but still felt the need to comment since I've come up empty as well besides this thread. We are remodeling a home in Wenatchee, WA that was built in 1928 and found the same exact thing you describe! And our first thought was coke house, too haha.
  4. olderthanyou | Apr 01, 2019 11:05am | #19
    Diatomaceous earth? It's used in everything from toothpaste to dynamite so maybe someone decided to try it as insulation.
  5. cap | Apr 01, 2019 10:51pm | #20
    I live in Sacramento, CA, and while doing electrical work for a client, encountered a fine white/grayish white powder in the house walls. Turns out it was rice hull ash. Rice has been grown to the north and west of Sac for decades, and milled locally, so there has been plenty of rice hull waste available. Although there is some silica in the hulls, my research at the time didn’t find any information suggesting it was a particular hazard (other than as a non-toxic dust).
    I don’t know if other grain hulls were burned and the ash used as insulation, but it’s possible. There’s a lot of wheat grown in Washington, and it’s likely milled near Seattle.
    Cliff
  6. rangersmith1 | Apr 02, 2019 09:46pm | #21
    While remodeling a 1936's bungalow here in Coeur d'Alene, Idaho, we also found a white powder in the attic after newer fiberglass bats. The walls had no insulation and all interior walls and ceilings were lath and plaster. Asking around some old timers suggested that back in the day gypsum powder was placed in the ceilings to keep the plaster dry and prevent damage if any small leaks occurred in the roof. I would guess the same. We scooped and vacuumed it out and blew in new insulation after installing baffles.
  7. Hvaczilla | May 08, 2019 11:01pm | #22
    I ran into a bunch of this today and nobody seems to have any idea what it is, I've heard arsenic for pests, asbestos powder, gypsum powder now. What is it really though??? Sidenote: we grabbed a sample and are going to get it tested.
  8. florida | May 09, 2019 07:26am | #23
    My bet is diatomaceous earth. Back in the hippie days of the seventies, it was the natural way to stop pests in your house. we put it in wall cavities, in the attic, everywhere a bug might crawl.
  9. Wawahomeinspections | Mar 26, 2020 04:34pm | #24
    This attic in walla walla was filled with the same powder , they were nice enough to leave the bags behind as to what it was
    1. rangersmith1 | Mar 26, 2020 07:22pm | #25
      So glad to see this. We're only about 30 miles east of Spokane so it makes complete sense. Kind of someone to actually leave the bag for future archeologists. So glad it wasn't worse since I inhaled and swallowed more than I would like to admit. Cheers.
  10. bcinvt | Mar 26, 2020 11:02pm | #26
    it would be bad news to inhale too much of anything that fine, and diatomaceous earth is composed of the microscopic shells of ancient sea life (diatoms), which makes it very abrasive at a fine level. That's how it kills bugs, they dehydrate from countless small abrasions. Also, it is basically silica, just like asbestos.
    Just like today, they threw all kinds of stuff around and nobody guessed what it might do. By the way, the diatomaceous earth used in pool filters has been heated to eliminate the sharp micro edges so it's safer around the house, but doesn't work on bugs.
