White Trex hole filler
Jebadia | Posted in Construction Techniques on November 26, 2009 06:52am
I have a question regarding the filling of holes in a Trex post sleeve.
My help got carried away trying to fasten railing to the sleeves and drilled before making sure everything was aligned correctly. Now I have some nail holes to fill and I am looking at some sort of epoxy that dries white maybe? I am not sure otherwise I am thinking caulk but I need to come up with something better than White wood putty.
Jeb
  1. DanH | Nov 26, 2009 09:09pm | #1
    How about taking a piece of scrap, cutting some slivers, shaving them down to fit the holes (tapered), and pounding them in (with a little glue of some sort). (Trim flush afterwards.)
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
  2. reinvent | Nov 27, 2009 12:13am | #2
    http://www.bondfill.com/
    http://forums.jlconline.com/forums/showthread.php?t=47322
  3. calvin | Nov 27, 2009 02:09pm | #3
    I had a sub that put some hardware in the wrong place on some textured bathroom partitions (commercial).  I took a sample of the material and bored some plugs, drilled the partitions and installed the plugs.  The textured surface helped the plugs disappear.
    http://www.quittintime.com/
