White vs gray thinset
| Posted in General Discussion on April 15, 2004 07:22am
What’s the diff in white & gray thinset?  I know white has to be used for certain stones, but is there any performance differences?  And did I ask this same question not too long ago?  My mind escapes me sometimes…
Whenever you are asked if you can do a job, tell’em “Certainly, I can!”  Then get busy and find out how to do it.  T. Roosevelt
    IMERC | Apr 15, 2004 08:10am | #1
    It went by a few minutes ago... Had I known it was yours I'd snaged it till you could have come by for it.
    Performance doesn't seem to be any different between the two. White, I think is smoother and costs more. White is generally used on porous stone and tile.
    Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
                                            WOW!!!   What a Ride!
    1. WorkshopJon | Apr 15, 2004 01:49pm | #2
      "White, I think is smoother and costs more"
      IMERC,
      No difference here 'cept the color.
      Jon
        IMERC | Apr 16, 2004 05:15am | #10
        I got ripped!!!Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....                                        WOW!!!   What a Ride!
  2. andybuildz | Apr 15, 2004 02:40pm | #3
    Ed
        USe white when using white marble as the color bleeds through as it does with limestone.
    Its also easier to use darker colors on dark tiles in case some oozes out .
    My life is my passion!
    1. Sancho | Apr 15, 2004 07:02pm | #4
      No diference as long as youre talking thinset to thin set not thin set to mastic which is white also. Then there is a difference.
      Darkworksite4:
      El americano pasado hacia fuera ase la bandera
      1. WorkshopJon | Apr 15, 2004 07:58pm | #5
        "mastic which is white"
        Ron,
        The pail I have is yellow...............I got ripped off.
        Jon
        1. Sancho | Apr 15, 2004 11:42pm | #6
          I dunno about no yellow mastic, the stuff Ive seen here and used is white.
          Darkworksite4:
          1. WorkshopJon | Apr 16, 2004 03:52pm | #13
            "I dunno about no yellow mastic, the stuff Ive seen here and used is white."
            Ron,
            See attached pic.
            Jon
            Edited 4/16/2004 8:53 am ET by WorkshopJon
          2. Sancho | Apr 16, 2004 04:51pm | #14
            Maybe its a manufacturer or regional thing but all Ive seen is white mastic. Im not doubting ya bro.  the only reason I brought mastic up was to make sure we (Ed the guy asking the Q and folks giving the answers) were on the same page. its hard over the net. Thats all.
            Darkworksite4:
            IMERC | Apr 16, 2004 06:25pm | #15
            What in the world are you crying about? Give ya yellow mastic which is gotta be more than white. It must take an additive or something to get yellow.
            Now the white mastic users are gonna havta revolt 'cause they are being shorted....
            Geeze...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....                                        WOW!!!   What a Ride!
        2. billyg | Apr 15, 2004 11:44pm | #7
          Will your grout be light or dark?  Use white thinset with a lighter grout and gray thinset with a darker grout.  That way the thinset that comes up between the tiles and that you missed when doing your cleanup (it will happen) won't be as prone to show through the areas where you have thin grout coverage over the thinset.
          The white is used more frequently on walls with a lighter grout, but it's not a big deal either way.
          Billy
          1. Scooter1 | Apr 16, 2004 03:26am | #8
            No difference except the color. White thinset for light tiles; grey thinset for dark tiles. White is $2 more per bag. Don't know why.
            Regards,
            Boris
            "Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
            dieselpig | Apr 16, 2004 03:42am | #9
            descrimination?
          3. trimnailer37 | Apr 16, 2004 05:22am | #11
            dieselpig-funny!
            i use white for light grouts, grey for darker grouts. don't know if it matters or i've simply convinced myself that it does.
            IMERC | Apr 16, 2004 05:27am | #12
            On some thin white or light marbles the gray may bleed thru.Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....                                        WOW!!!   What a Ride!
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
