has anybody here used Superior Wall system for a basement?? how did the cost compaire to poured walls or block??? do u think it was worth the money?? and do they leak??
tell me all i need to know about these foundations.
For a stable, flat, and squeak-free floor, you'll find that most new products are OSB.
From what I have seen the cost is about the same, provided you dont have to many corners , which can get expensive. If your going to be finishing your foundation then it would pay to use them . If not stick with block or poured, ( Time Tested). Good Luck.
