Outside a walgreens in south carolina- store does not know
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
more info
it is metal with plastic slats
Did you turn one over to look for a label on the back/bottom? Most would have the manufacture's label somewhere.
(I'd guess that there are a dozen or more different manufacturers of such benches.)
I did , no labels.
The Park Catalog or Uline should have something like that.
Look for contoured commercial park benches.
http://www.theparkcatalog.com/recycled-plastic-and-vinyl-benches/contour-benches
Them things ain't cheap.
