Whole house fan thru wall?
| Posted in Energy, Heating & Insulation on January 31, 2003 11:18am
I’m building a house with a SIP roof–no attic. I want to install a whole-house fan on an outside wall. I haven’t been able to find any through-the-wall fans that have the high CFM ratings of whole house fans. (I’m looking for around 3500 CFM.) Is this just not done? What am I missing? Thanks!
  1. UncleDunc | Feb 01, 2003 01:36am | #1
    Where's the makeup air going to come from? That flow rate would expel all the air in my house in 4 minutes.
    1. CathyIN | Feb 01, 2003 06:30am | #3
      The idea is to use the fan as a whole house fan, to bring cool air in through the open windows on summer nights. Just like the fans that are normally installed in the ceiling.
      1. don26299 | Feb 01, 2003 07:37am | #4
        I have one in my house (a moble home with walls around, truss roof over,  small attic).  I made it myself and it WORKS GREAT!
        It consists of a Patton or (similar) Windmere (50$) approx 15 inch high speed fan.  I cut a circle in a 3/4 plywood which sets in a flashed window-like jamb.  Outside are louvers which open with a choke cable inside.
        In the winter we install a piece of foamboard.
        Except for those few scorchers I think it is far better than sleeping in air condx.
  2. fredsmart48 | Feb 01, 2003 02:54am | #2
    If you want a big cfm fan go to a company that sells grain drying equipment for grain bins.   You may have to add some supports to the wall but it will exchange the air for you.
    rjw | Feb 01, 2003 10:52am | #5
    FWIW, I sometimes see a jury rigged furnace blower used that way
    _______________________
    "I may have said the same thing before... But my explanation, I am sure, will always be different."  Oscar Wilde
  4. user-216037 | Feb 01, 2003 03:52pm | #6
    HI, Consider a greenhouse fan. Search for commercial GH suppliers, Griffin, Winandy Rough Bros. as a source. Lots of size and power options, also louvers to close when not in service.  3500 is alot of cfm, have you figured close for your heat drop needs.  I used to be in the greenhouse biz and two 3500cfm fans took care of a 30X96 greenhouse with full solar gain, hard to see your needs that high, but heck, I'm in Maine.
    Good Luck,  Will
