Does this sound like a viable solution?
Edited 8/4/2009 10:29 am ET by philippar
A custom finish carpenter shares how he designed and outfit his two-car garage shop with all the tools, jigs, and accessories he needs to comfortably do great work.
Greetings phil,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
94969.19 In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
Let's run this through again.
bump
Well I don't know about your specific situation but we have an ERV bringing about 135 CFM into a central area of the house and it works great, especially in the wintertime.
Questions in your other post are unanswered. We need to better understand what you are trying to accomplish. Ventilation is one thing. Destratification is another. What it the problem you are trying to resolve? Your post is a bit confusing. What are you trying to achieve?
Having positive pressure ventilation may not be a good thing particularly in the UK. Positive pressure venting is going to force moist inside air into the construction (not a good thing). Most the time we use negative pressure venting (i.e. exhaust fans combined w/ various strategies to let the fresh air in (e.g. cracking open a window, window vents, natural air leakage of the construction if you have a leaky house, a fresh air damper interlocked w/ the furnace fan/exhaust fans, etc.
If you have high moisture levels in the house, positive pressure venting should not be used.
