what are the best easry to use inexpensive computer programs for cost estimating? or does anyone have a spread sheet to share ?
Hawkeye I would need a little bit more information before I could even begin
to start recommending an estimating solution for you.
etc.? There is no one solution fits all as far as estimating is concerned
in my opinion. The database I use has 337 line items devoted to just stairs
& railing items. Unless you are doing stairs and railing as a specialty
that kind of detail is meaningless and would swamp you with things to account
for if you are trying to estimate as a GC.
about how much you know about estimating might help too.
Cost functions later on?
or will you enter data manually when you need to.
part of a spreadsheet if that the way you choose to go
know about using Excel?
I have a FileMaker based database solution that I use that I will at times
distribute as shrunken version to subcontractors I work with for them to use.
You can try out if you like. I'm in the midst of revising it as we speak but
I might have that revised version available by the middle of this coming week
if your interested.
“Systemize the Routine; Humanize the Exceptionâ€-
from Customer Culture: How FedEx and Other Great
Companies Put the Customer First Every Day
by Michael D. Basch
I am a residential custom homebuilder in the 200-400 thousand range yes i would like to try. thanks so much
I appreciate u taking the time to respond . I would very much like that spreadsheet if you can send it>
