Why are Pre-Hung Doors Narrower than …
| Posted in General Discussion on July 18, 2000 04:11am
I went to one of those auctions of construction materials, and bought some prehung doors; door was fine, but the rest was trashed. That was fine with me, because I only wanted the doors for a remodel.
I unscrewed them, threw the frames away, and went to the house to install them. Lo and Behold! They were 1/4″ too narrow. Hmmmmm! Went to the Big Box and measured prehung and slab doors. The prehungs had an OPENING equal to the nominal size; the slabs themselves were the nominal size. (Example: 2-6 prehung measured 29-3/4 wide; 2-6 slab is a full 30 wide.)
b WHY???
  1. Guest_ | Jul 18, 2000 12:46am | #1
    because no good deed goes unpunished.....
    1. Guest_ | Jul 18, 2000 01:48am | #2
      *use a wider door stop and dont worry about the punishment
      1. Guest_ | Jul 18, 2000 01:58am | #3
        *John,
        The doors are most likely beveled. You are probably measuring on the beveled edge. When you buy a slab door it's either sold as pre-beveled or square.
        View Image © 1999-2000"The first step towards vice is to shroud innocent actions in mystery, and whoever likes to conceal something sooner or later has reason to conceal it." Aristotle
        1. Guest_ | Jul 18, 2000 04:01am | #4
          *I our area the standard for a pre-hung doors is 3/16" undersize to the high side of the bevel and the inside measure of the jamb is full size. The jambs tend to be about 9/16' thick so the overall width is smaller than the old rules I saw many years ago. I figure that things tend not to be square, level and plumb so the smaller the better.Some door shops buy their door blanks under sized and with a bevel. My experience is that they are sized inconsistantly. I have better luck with the shops that buy full size door blanks and under size them on their door machine when they joint the edge bevel.
  2. John_Myhre | Jul 18, 2000 04:11am | #5
    I unscrewed them, threw the frames away, and went to the house to install them. Lo and Behold! They were 1/4" too narrow. Hmmmmm! Went to the Big Box and measured prehung and slab doors. The prehungs had an OPENING equal to the nominal size; the slabs themselves were the nominal size. (Example: 2-6 prehung measured 29-3/4 wide; 2-6 slab is a full 30 wide.)
    b WHY???
  • Smarter Stop Block
