What benefit is there in using pressure treated plywood sheathing under stucco lathe rather than regular plywood in a Florida coastal environment?
To prevent moisture buildup and improve performance, install a continuous air barrier—such as drywall or specialized membranes—under tongue-and-groove boards or other interior wall paneling.
termites
and rot!!!
Termites can be / should be treated, but water or moisture can wick up into the bottom of the plywood at the base of the wall.
We usually only use a rip of TR plywood at the bottom of the wall 12" - 24". This works especially good with walls over 8'. We sheath the upper portion of the wall with regular plywood or OSB.
For added protection install 18" wide poly at the bottom of the framed wall about 8" up on the wall prior to sheathing, after the plywood is installed we wrap the poly up the wall on the outside prior to Tyvek.
the further necessities having arsenic in society : )~
When we meet, we say, Namaste'..it means..I honor the place in you where the entire universe resides, I honor the place in you of love, of light, of truth, of peace. I honor the place within you where if you are in that place in you and I am in that place in me, there is only one of us.
