Why Roll Vinyl Flooring Pattern Out?
WayneL5 | Posted in General Discussion on January 23, 2005 05:53am
I just finished my first sheet vinyl flooring installation in my own home bathroom.  It went great and was as easy as I hoped it would be.
The instructions that came with the installation kit said in a couple of places to roll the vinyl pattern side out, even the final time before laying in the room, which made it difficult to unroll and shuck around into place.  Why would it have be incorrect to roll it pattern side in for bringing it into the room for final placement?
  1. highfigh | Jan 23, 2005 06:05am | #1
    After you lay it, it's going to try to go back to its original position, due to memory. It was rolled pattern side in not long after it was produced and will want to stay in that position.
  2. catmandale | Jan 23, 2005 06:09am | #2
    Wayne, it depends.
    If it was a homogenous vinyl with no separate backing, they may be concerned with it shrinking as it was "backrolled", only to have it 'grow' as the vinyl "memory" kicked in.
    If you precut the flooring using a pattern, shrinkage could be problematic as well if it was backrolled after the cutting process, resulting in a slightly smaller piece that you cut.
    I haven't installed floors for many years, but I used to backroll it before I traced my pattern and then roll it backing side out after taping all my stress points as well as the rolled material.
    The method of adhering the floor may matter too. If you are doing a perimeter job, they may be worried about the end curl and the material not laying flat.
    Food for thought.
    Dale
