Will My Roof Fall Down?
DannyWhitty | Posted in Construction Techniques on June 15, 2018 02:56am
Hey all,
 I’m installing a ceiling cassette heat pump in my attic and there are two 2×4 that are in the way.  I can’t tell if it’s a structural truss or if it was temporary truss put in place during installing (and currently serves no purpose).  It runs from gable wall to gable and I would need to cut 16″ off the chord end which would essentially remove connectivity between the load-bearing walls.  I was wondering if you fine people would be willing to take a look at the pictures below and let me know if making this cut is a bad idea.
Here’s a picture of the attic
Here’s a rough sketchup of what’s going on in my attic:
Here’s an sketchup of the section I’d like to remove:
Here’s a picture of an old set of plans I found that make no mention of a truss in the attic.
I appreciate any help/knowledge you all are willing to share.
  1. FlyingContractor | Jun 15, 2018 09:47pm | #1
    It looks to me like what you are referring to is a "strong back".  Appears to be a stick framed roof and the strong back maintains the spacing between the ceiling joists.  Typically once the drywall is installed on the ceiling below, the strongback isn't absolutly necessary.  I hesitate to recomend removing it though without physically examining you specific situation.  Perhaps you could "header off' what you want to remove and thereby continuing any lateral load.
    1. DannyWhitty | Jul 02, 2018 10:06am | #2
      Thanks for the feedback.
