Will the angle iron work for my span
Cody0469 | Posted in General Discussion on October 14, 2018 02:34am
Will a 1/4 in think angle iron work on a 9ft opening with 3 or 4 course of hollow block above it thw pieces I have are 12ft long and 3x3x1/4 blocks are 8x8x16 no roof wieght bearing on wall
  1. DanH | Oct 14, 2018 07:17pm | #1
    Uh, the thickness of the metal is less important than the dimensions of the ell.  You need to support 800-1000 pounds.  There are some calculators online, but I haven't worked my way through them.
  2. junkhound | Oct 15, 2018 04:52am | #2
    no way
    just too check.
    section mod = 0.56
    moment = = w*lsq/8 = 52k
    w= about 20# inch  =  12 in long block, 4 courses * 60 # block?
    l == 144
    52k needs to be less than  20ksi*0.56  = no
    now, the 20ksi is code allowable, yield say 70ksi
    still likly to bend unless reall light weight block (< 10#/block)
    1. Cody0469 | Oct 15, 2018 09:09am | #3
      Also i was going to put one on each side
Outdoor Lighting
