Williams & Hussey Molder/ Planer, W7-S, power in/outfeed. Excellent condition, used very little. Original equipment stand and 2 HP Baldor motor. Dusthood. Located Hyannis, Mass. $1000.00. Substantial savings over new. No molding knives available, just the straight planer knives on the machine.
Listeners write in about deepening foundations and ask questions about HRVs, smoothing rough concrete, and finding the right workwear.
Builder’s Advocate: An Interview With ViewrailRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
Wish you were closer. That's a pretty good deal.
You probably won't have that long, but I'm probably coming down to JLClive in RI in a month. I have some intrest, but sell if the cash shows up.
Why the wood block under the Baldor?
What sort of switch do you have?
Keep in touch. There is no switch, just a plug-in. The block just keeps weight and tension off pulleys and shafts when not in use.
Dan
I'll look back in here before that trip to contact you and see if it's stillavailable. it does not look like you have used it much.
you like it THAT much that you want two?
"As I was walkin' - I saw a sign thereAnd that sign said - no tress passin'But on the other side .... it didn't say nothin!Now that side was made for you and me!" Woody Guthrie 1956
Sure thing if I got the bling.One of my subs liked mine so much he went out and picked up a used one, and another used one.With four, we could have chariot races...Really, one can stay set up as a planner while other can do finer millwork. Or a design that requires two different setups can go faster in production.
Or I can have one at the shop and one on the job....Or one could someday become a parts machine to canabalize for the other.
Find any reasonably priced cutter makerers?
yes and no.
One of my guys lives next door to a machinist who says he can do it, but I haven't tried him yet
Has this sold yet?
Yes
