Williams wall furnace
domenica | Posted in Energy, Heating & Insulation on December 24, 2007 09:49am
Hello. I do not know how to send pictures yet. I am going to learn: so, I am going to describe as best as I can. I have in my living room a wall mounted gas operated furnace. When I turn the thermostat on, and the room gets warm I hear a metal banging noise like hitting a metal with a hammer. The lower portion of the furnace is the blue flame: the upper portion is the very large metal. In HVAC language they call it the heat exchanger. The noise, I presume comes from expansion or contraction of the metal. Has this happened to you? Are there adjustable screws to allow tolerance for expansion? Thanks in advance.
Greetings from California! Merry Christmas.
Edited 12/26/2007 1:20 am ET by domenica
  1. rez | Dec 27, 2007 07:55pm | #1
    And Greetings to you from Breaktime!
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers and Best of the New Year to You.
    BillHartmann | Dec 27, 2007 09:16pm | #2
    One possibility is that the furance or vent was not installed properly. That part of it was installed so that the unit is twisted or that that the fasteners are too tight and don't allow for normal movement.
    Get the full brand, model, and manufacture's name from the lable and see if you can find the installtion instructions on the web.
    1. domenica | Dec 28, 2007 10:24am | #3
      Thank You. I was almost sure it was the fasteners to be adjusted so there would be more tollerance or "play". I checked the web for Williams Furnace. I saw your profile, I do not know where Anchor, Dr is .What State?  Thanks
        BillHartmann | Dec 28, 2007 04:32pm | #4
        I am in MO, in the Kansas City area..
  3. jvl | Dec 28, 2007 04:48pm | #5
    just had my williams furnace on.just to let you know,i have the same noise coming out of mine for the past few years.the two others before this also had the banging.the expansion of the heat and cold.not much you can do about it.its a cheap heater and the design has been around for a long time.model #5009622.casing may be distorted by being fastened to an uneven opening or jammed under header,expansion noise.1-800 266-0993 or 1-909-825-0993.good luck
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
