window install v. furring strips
| Posted in Construction Techniques on January 9, 2002 07:06am
i’m having trouble working out the best way to install marvins’ double hung sash windows to my walls. i have been recommended to put 3/8″ furring strips on top of the plywood, i think this is a good idea. but should i install the windows on the plywood sheathing or the furring strips?
appreciate any help!
  1. Mike_Smith | Jan 09, 2002 05:36am | #1
    eddie... i don't know what you are describing...
    is your wall thinner than the normal ?.. why does the Marvin need a 3/8" shim ?
    1. Mongo_ | Jan 09, 2002 07:06am | #2
      *Are you installing a rain screen on the exterior wall between the sheathing and the siding? Assuming a rainscreen detail:One thing to consider...if the window comes trimmed out, that may dictate what you have to do. If the thickness of the trim can't absorb the 3/8ths furring and the thickness of the siding and still give you a good reveal, then you'll have to furr the windows out as well. Or you can backband the "too thin" marvin trim to beef it up a bit...though that sometimes creates problems of its own.If you'll be installing the window trim on your own, you can mount the windows right to the sheathing and just install a thicker trim.Watch the flashing details around the windows if you do furr them out.
Old House Air-Sealing Basics
