Window Jamb Liners
Prado | Posted in Construction Techniques on June 13, 2008 10:32am
I’ll be installing jamb liners for a new set of sash windows (two windows).
What advice does anyone have about the installation of jamb liners?
Should I avoid them and use clock springs or spiral springs instead?
Thanks!
  1. WINSTALL | Jun 13, 2008 10:51pm | #1
    Where did you get the sash? Where did you get the liners? Will the work with each other? Need more info.... What is wrong with the existing liners? Is this a rope & weight window unit?
    As long as GOD makes "bad builders" and rich people... I will have a job
    1. Prado | Jun 14, 2008 10:15am | #2
      I haven't gotten the jamb liners yet.
      I will make the windows myself to replace existing louvre windows that were installed the in the washroom of my old house. I don't have enough carpentry experience to make the casements and window sills and exterior molding, etc. for traditional weight and pulley double hung windows. I can make the windows, however.Thanks for your response.
      1. WINSTALL | Jun 14, 2008 03:14pm | #3
        Not sure of the size of your window, but, most of the old jalousie windows were "standard" sash openings. I would look in to a sash kit and see if that won't save some time & money. M/W makes a nice unit for the $$$$$$. What size is your opening? What slope is the sill?As long as GOD makes "bad builders" and rich people... I will have a job
        1. Prado | Jun 14, 2008 11:07pm | #4
          THe opening is 41 x 42 1/2.
          There is no slope on the sill as it does not project to the exterior of the house. As I mentioned before there are louvre windows there currently but I suspect that the louvre windows there are not original to the house.Perhaps there were windows that opened out like doors...?Does this information help?Thanks!
          1. WINSTALL | Jun 16, 2008 02:33pm | #5
            Marvin makes a product called "tilt-pak". To fit your opening with a custom bevel for the bottom sill, primed wood and Low-E I.G., it should run about $415.00 + tax. That would be the way I would go. At least you would have a guarantee.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
