what material is used to finish window sills. wood, drywall etc?
Listeners weigh in on Brian’s haunted showerhead and ask questions about covering overhangs with trim coil, sealing air leaks, and how to partially finish a basement.
Video: Build a Fireplace, Brick by BrickRelated Stories
interior or exterior ?
What kind of look are you going for? What type of windows are they? (wood clad, vinyl, etc?) Budget? Type of room and asthetic vaue?
interior
I like wood. Drywall reminds me of a motel.
How about stone or solid surface (Corian) material.
Johnny, I do a lot of work for an architect/developer/contractor who uses aluminum sliding windows with top and side sheetrock returns. Sills are whatever flooring or cabinet species he's used, with a 1/4 round underneath...
Usually we'll do the sill in some corresponding material fo the house...If the trim throughout is VG Fir, then so is the window treatment, if there is alot of stone in the bath/kitchen, try to incorp. stone, wood floors=wood sills. I agree with about everyone..if it's drywall wrap...Ick. But it IS YOUR place. (At the least give the sills some treatment, if not boxing in the whole thing, IMHO) Good lUck
PS - We do alot of pine sometimes...Don't feel because it is inexpensive that it is inferior. The attention to detail, like Andy is saying, goes on and on...Do it right and tight. Your NOT going to paint this in the end, R U??
Edited 8/20/2002 12:57:16 PM ET by PostnBeam
I never even heard of using sheetrock to finish a window sill. Am I missing something here? I almost always fabricate my own sills out of clear 1x or 5/4" pine. I run different router bits over the fronts depending on what look the customer wants. Ogee, or a simple round over etc etc. Its a lot less expensive then buying it and looks a lot better IMHO
Be well
Namaste'
Andy
It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
I see some drywall returns here (NE IL) but as someone said, I always feel like I'm in a motel or some cheap office building.Jon Blakemore
We see alot of the mdf board used hear, caulked and painted to seal and finish. Mostly white.
Alex
