Window Trim
| Posted in General Discussion on April 20, 2004 08:40am
I currently have Andersen terratone windows, with no window trim.  I plan on redoing the siding with Maibec WC shingles pre-treated with the cabot bleaching oil (anyone use the Waska’s with Olympic?)
I have found a place with clear white cedar dimensional lumber (5/4) for trim and corner boards.  If I did white cedar shingles, does it make sense to trim out the windows with this white cedar (bleached on site w/cabots) to match the weathering of the siding?
Do you think it would look better to do this trim vs just using the andersen window casings as the “trim” and running the shingles right up to the casing?
Thoughts on this?
Thanks so much,
Ian
  1. barmil | Apr 21, 2004 05:00am | #1
    Depends upon the house design, wouldn't you think? Contemporary, colonial, gothic, etc. Some designs invite stark trim and others demand framing.
    Canabuild | Apr 21, 2004 05:12am | #2
    Just use some caulking.
    "we may not be fancy, but we sure are expensive"
  3. MojoMan | Apr 21, 2004 05:34am | #3
    As Barmil said, it depends on the style you're going for. It is not uncommon to see Andersens finished with supplemental trim, as the stock frame is a little skinny for many styles. Follow the usual rules regarding flashing, etc. Cut  rabbets in the back of your cedar so the casings lay flat over the Andersen flanges.
    Al Molliitor, Sharon MA
  4. fartherhome | Apr 22, 2004 06:30pm | #4
    In most cases I think a window looks better with casing.Use a style that speaks the same language as the house.ive been making casings more and more with pvc trim,sometimes milling a sill from 2x trex. i think your casings will look better painted unless the house is very rustic.good luck.
