Window trim finish
user-67934 | Posted in Construction Techniques on May 24, 2007 12:52pm
I have clear pine window frames.  What is the best clear finish to use on the inside to protect the wood from moisture damage (normal condensation) and is still non-yellowing?  I fear that regular polyurethane will yellow over time.  I considered lacquer, but decided it may not give me the moisture protection I need.  Thanks.
Tony
  1. Shep | May 24, 2007 12:56am | #1
    A water-base polyurethane should give you the results you want.
    Just be sure to try it on a sample first- because it doesn't have any oils in it, some people think its too clear. You have to get the wood color right before you top-coat.
Outdoor Lighting
