Window trim paint recommendations
rkohler | Posted in Construction Techniques on July 28, 2002 08:53am
Hi,
I’ve replaced all my windows with Anderson wood windows.  I’ve trimmed the interior of the windows with MDF moulding.  I’m now at the point where I need to paint the trim and interior of the windows.  I’ll be primering and painting the trim with latex primer and semi-gloss with my HVLP sprayer, the walls will be painted with brush and roller in flat latex.
My wife wants me to mask around the casing by about 2″ so that the wall gets some semi-gloss as well.  She wants to then sand the semi-gloss up to the edge of the casing and use and edge tool to paint the wall, believing it will provide a cleaner edge.
I want to mask the casing right at the wall, being concerned about flat latex wall paint adhering to the semi-gloss (even though it’s been roughed up with sandpaper).
Anyone have a recommendation or is it a don’t care?
Thanks for help in resolving the domestic dispute.
– Rob
  1. Joe_Fusco | Jul 28, 2002 10:27pm | #1
    Rob,
    I'm a big fan of HVLP sprayers, but I think you'd do better with a brush painting your windows. The brush will also eliminate all that "masking".
    If you wish to still use the spary gun then I'm with you and mask right to the joint between wall and casing.
    1. Piffin | Jul 29, 2002 12:12am | #2
      I agree with Joe about brushing the trim, or at least brushing it out after sraying but I don't see any broblem with overlapping unless one is oil and the other latex
Outdoor Lighting
