Windows making me unhappy
Krico | Posted in General Discussion on December 24, 2008 06:57am
Hi All,
I recently remodeled a rowhome that I am keeping as a rental.  I had a window company come in and supply/install the new vinyl replacement windows.  That was about 3 months ago.   The new windows replaced older replacement windows that had broken panes, frames, etc.
Anyway, now that winter has arrived I am really unhappy with these windows.  They leak an unacceptable amount of air for new windows.  I rent the rooms in this house and one of the  tenants was complaining that she was really cold in her room.  I ended up having to put plastic up over the windows to block the cold air.  One of the things that I noticed is that the gap between the sash and the jamb varies a lot. At its widest ( I estimate maybe 3/16″), I can easily stick the blade of my Starrret combo square through the gap.  I want to go back to the vendor and get them fixed or replaced.  I know that I am going to have a real fight with them on that. Especially after I had to fight them to replace a warped frame on one of the windows. I could see light coming through that gap.
I probably will end up going to court on this.  I was thinking of hiring someone to do an energy audit so that I will have something to take to court.  Does anyone else have any ideas of some things that I can do to prove to a judge that these windows are unacceptable?
    Huck | Dec 24, 2008 07:42am | #1
    switch to a mac.
    just kidding
    "...craftsmanship is first & foremost an expression of the human spirit." - P. Korn
    bakersfieldremodel.com
  2. Piffin | Dec 24, 2008 02:08pm | #2
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=114309.1
  3. MikeSmith | Dec 25, 2008 12:57am | #3
    you might be able to convince a judge...
    but anyone who has any knowledge of windows knows that  quality installation makes quite a bit of difference..
    sounds like you got a bad installer.... who is proably also  selling  a substandard product
    but the devil is in the details..... what is the spec and what does the contract say ?
    were these old double hung ?  did they have window weights ? if so.... how did they treat the weight pockets?
    good replacement windows and good installation practise will usually improve perfomance over the old windows
    sounds like you got jobbed
    1. frammer52 | Dec 25, 2008 01:09am | #4
      Mike it sounds like the middle is not shimmed.  There is normally a built in shim on vinyl replacement, or rather there used to be.  Haven't installed any in a couple of years.
      1. MikeSmith | Dec 25, 2008 01:27am | #5
        taking hacks to court is not something that lends itself to a positive experienceMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
        1. frammer52 | Dec 25, 2008 01:37am | #6
          I would think it would be better to find a local carpenter with some knowledge of windows and pay to correct.  Forget about a lawsuit.  They are next to impossible to collect.
  4. KenHill3 | Dec 25, 2008 08:15am | #7
    Sounds like the installer racked the window unit.
