Winter Window Insulation
Nrgsaver | Posted in Energy, Heating & Insulation on October 10, 2008 10:13am
Hi Everyone,
I am doing research on window insulation. I am working for a non-profit that is trying to retrofit a number of its old buildings to reduce oil usage (by *old*, I mean built in the late 18th century). So far, I’ve been able to find out about window kits that come in specific sizes that have shrink-wrap plastic. I think what we really need is something that would make a really good seal, but comes in bulk so that we can fit it to windows that aren’t necessarily a standard size.
Has anyone ever heard of a type of stripping that might be placed between the outer window and the inner window to reduce air leakage from old sash-style windows?
Any ideas?
Thanks,
Nrgsaver
  1. DanH | Oct 11, 2008 01:19am | #1
    I have in the past (some years back) seen the shrink-wrap kits come in a multi-window package with fairly large pieces of plastic.
    Corporation: n. An ingenious device for obtaining individual profit without individual responsibility. --Ambrose Bierce
  2. DanH | Oct 11, 2008 01:20am | #2
    There are strippable caulks designed for temporarily sealing windows. Apply in the fall like caulk and just pull loose in the spring.
  3. shellbuilder | Oct 11, 2008 01:32am | #3
    Check out http://www.builditsolar.com He has done some things with twin wall plastic panels that looks easy.
    Edited 10/10/2008 7:19 pm ET by shellbuilder
  4. Jay20 | Oct 11, 2008 06:57am | #4
    Check out http://www.windowsaver.com
    1. Nrgsaver | Oct 14, 2008 10:32pm | #8
      Jay20,I went to that site; they're on my list of potential solutions. Thanks for your help!Nrgsaver
  5. reinvent | Oct 11, 2008 01:19pm | #5
    I will second the window saver kits. You buy your own plexi glass (1/8") and stick the magnet strips to the back of them and the metal strips to the window frame.
    Also check out
    http://www.conservationtechnology.com/
    And click on weatherseals and go to pg 26 center seals
    Also
    http://www.energyfederation.org/consumer/default.php
    1. Nrgsaver | Oct 14, 2008 10:35pm | #9
      reinvent,Thanks for the suggestions; I'll certainly check them out.Nrgsaver
  6. Harold Pomeroy | Oct 12, 2008 04:46am | #6
    Check out the forum at Historic Homeworks.
    http://historichomeworks.com/forum/index.php
    The people there work with windows in old houses, and can give you some professional advice.
    Harold Pomeroy
    1. Nrgsaver | Oct 14, 2008 08:12pm | #7
      Thanks! Will do.
