wiring a mini split heat pump
shawncal | Posted in Energy, Heating & Insulation on July 2, 2011 05:46am
Hi all,
I’m installing a single zone mini split heat pump/AC unit on our house and have a question on the wiring.  The unit calls for a 120V 20amp dedicated circuit, but the manual does not mention the need for a service disconnect near the compressor…so I’m wondering if the service disconnect is required for mini splits as it is for central AC units.
Also, if I do need the disconnect, are there boxes specifically made for these small 120 v units (I went to our local big box store and all they had were 60A/240v boxes…)?
Any help appreciated!
  1. gfretwell | Jul 06, 2011 12:53am | #1
    Yes, you need a disconnect ... and a service outlet (GFCI protected receptacle) near the condenser.
Picture-Perfect Pergola
