Wiring a new cooktop to old wiring
Cabin | Posted in General Discussion on March 1, 2009 09:43am
I just had a friend call me with a wiring question about replacing a cooktop.  The supply is 10 gauge 3 wire copper and the new cooktop has 4 wires coming out of it.  Any idea what to do with the extra wire?
  1. JeffinPA | Mar 01, 2009 06:44pm | #1
    Code now requires a 4 wire installation.
    The old way was Black-black, red-red, ground-white.  (The ground wire coming from the panel was used as the neutral)
    Now you are required to run a 4 wire back to the panel so that you have both a neutral and a ground wire connected to the cooktop.
    I wont suggest that you hook it up otherwise.
    1. gfretwell | Mar 01, 2009 08:51pm | #4
      Actually the neutral was used as the ground. (a subtle difference)
      The code only requires the 4 wire circuit if you are running a new one. You can still hook up to the 3 wire.
      There wasn't really a body count tied to the code change in 1996. It was just done for uniformity.
      1. edwardh1 | Mar 01, 2009 08:59pm | #5
        Check the size wire required on the new cooktop- mine - a GE required a switch from the old 10 ga 30 amp to a 8 gage 40 amp. even tho it waas just barely into 8 gage ampacity
    Dam_inspector | Mar 01, 2009 07:14pm | #2
    I wouldn't connect the white and green together.
  3. MrBill | Mar 01, 2009 08:45pm | #3
    Cabin,
     I am not an electrician so you can take this as you like but.....
     Read the instructions. Code does require 4 wires IF you are running a new circuit, but if you already have a three wire run, you tie the neutral to the ground at the cooktop. I just did this exact thing when we replaced our oven about a year ago. The installation instructions made the procedure very clear.  There was a terminal supplied in the range to tie the two together.
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
    Edited 3/1/2009 12:47 pm ET by MrBill
