Wiring thermostat to new wall heater
Brickie | Posted in Construction Techniques on February 11, 2010 12:14pm
Gosh, I can’t believe I’m hung up on this particular task (at my own house), but please, somebody, give me a pointer as the manuals are worse than poor. It seems to me like a thermostat is just a fancy switch, and swiches, generally are wired in-line, ahead of the switched devise. What I’ve got is a Cadet forced-air, 120v, in-wall heater and a standard digital thermostat. Do I simply lead power (yes, I did install a new, separate 15a breaker for this appliance) to the thermostat and pigtail those wires to the heater? Is it that simple?
    coonass | Feb 11, 2010 01:02pm | #1
    Brickie,
    Simplest way is to use a line voltage thermostat and wire it like you said. Most common thermostats run from a transformer to a contacter to power up heaters and AC units.
    Box stores carry line voltage stats.
    http://www.heatersplus.com/et.htm
    KK
  2. DanH | Feb 12, 2010 10:26pm | #2
    Note that you need a LINE VOLTAGE thermostat -- you can't use a standard low-voltage unit. (You can try, but the new thermostat won't last 15 seconds.)
