Wood eavstrough for Barn
user-246028 | Posted in Construction Techniques on September 3, 2007 04:25am
Hey all,
I have a customer that is interested in wood eavstroughs for his barn. The barn is a historically accurate design in old Niagara-on-the-Lake and he doesn’t want to ruin it by putting on a modern gutters. I suggested wood (not having a clue what I was talking about)
Your input here “wood” be greatly appreciated.
Thanks,
Dave
  1. RedfordHenry | Sep 03, 2007 06:10am | #1
    I re-did a barn that had a simple gutter over the main door.  It was made of two cedar 1x6s nailed together to form a V and was mounted against the siding on site built brackets (also wood).  It functioned pretty well.
    Also available are solid fir gutters.  I recently replaced one that was 32' long without any seams.  Had to special order it from my yard, I think it was about $14/ft.  While the gutter itself is about 4" square in cross section, the actual water groove is only about 1.5 inches. square.  Not much actual capacity, so if the barn has a lot of roof to drain, it may not be a good choice.  High maintenance as well, so if it is up really high, or if the HO is otherwise not inclined to keep it clean and painted, is probably not a good choice
      user-246028 | Sep 03, 2007 09:54pm | #3
      You wouldn't have any pics of it would you?
      Dave
      1. RedfordHenry | Sep 03, 2007 11:49pm | #4
        Which one are you interested in?  I don't have pictures of either, but the 1x6 isn't too far away.  The one piece fir is close to an hour away.
          user-246028 | Sep 04, 2007 03:01am | #5
          Which ever is the most convenient for you to get
          Dave
  2. seeyou | Sep 03, 2007 01:59pm | #2
    http://forums.taunton.com/tp-breaktime/messages?msg=74657.1
    http://forums.taunton.com/tp-breaktime/messages?msg=41162.1
    http://forums.taunton.com/tp-breaktime/messages?msg=35380.1
    http://forums.taunton.com/tp-breaktime/messages?msg=91089.1
    What you need should be in there somewhere.
    http://grantlogan.net/
    "he ot the placed closed down whyyy thhhattt nnooo gooodddd" - sancho
    1. Piffin | Sep 04, 2007 03:29am | #7
      Right on the ball this morning weren't you?;)
  3. Piffin | Sep 04, 2007 03:28am | #6
    We've had a few threads here on this. Search the term Wood Gutter.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
