Wood filler for a deck
JohnT8 | Posted in General Discussion on June 13, 2005 07:38am
Does anyone have a preferred wood filler for exterior use  (midwest temp range… -20 to 100+) that could be used on a wood deck?
Deck seems to consist of regular kiln dried and pt lumber.  The floor portion is getting some exterior carpet, the rails/spindels are getting hit with exterior house paint (kilz, then ext paint).
HO wants countersunk screws on rails/spindels filled prior to painting.
A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty. — Sir Winston Churchill
  1. Isamemon | Jun 13, 2005 08:18pm | #1
    Epoxy, bondo
    home page of this forum even has an article on it rihgt now.
  2. FastEddie1 | Jun 13, 2005 08:26pm | #2
    The carpet is going to trap moisture and promote wood rot.
    1. JohnT8 | Jun 13, 2005 09:38pm | #3
      That would fall under the catagory of: NMP  ;)
      Although it probably wouldn't be a problem if they swapped out the wooden decking for one of the plastic-deckings now available.
      As long as the deck rail/posts/spindels look ok, that's all I have to worry about.
      A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty. -- Sir Winston Churchill
      Edited 6/13/2005 2:42 pm ET by JohnT8
Picture-Perfect Pergola
