wood finish
sunsen | Posted in Construction Techniques on August 12, 2017 07:49am
Anybody out there found a better product than Sikkens “Door and Window” for clear coating interior wood that will have a lot of UV exposure due to its being in a glass house? Apparently Sikkens has changed their formula since we last used it and it darkens the wood too much.
Thanks.
  1. benwatson | Oct 25, 2017 08:08am | #1
    well there are so many you can google it, but it depends which type of material is best according to your requirement
    user-2409187 | Oct 31, 2017 09:25am | #2
    Regular maintenance
    My experience with Sikkens is limited to its outdoor products, with UV/UA inhibitors. The presence of these inhibitors naturally darkens the finished appearance. Check Cabott products for exterior wood, and you will see that they too render a deep, rich, color. For interior applications in sun-drenched conditions, I suggest a "regular stain" followed by a clear finish with UV/UA inhibitors. And, more importantly, you need to maintain the finish regularly. There is no way to mitigate the harm done by good ol' brother sun. :)
    Here's something to consider: Stain interior trim, but use matching paint for window SASHES (only). Paint that part of the window most suseptible to UV/UA and condensation damage, and stain the rest. If you do a careful matching of colors, the two products will complement each other well. Painted wood is, in my experience, easier to maintain than stained woodwork.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
