wood floor finish
| Posted in General Discussion on September 20, 2006 03:24am
my daughter wants to use a linseed oil finish on her newly sanded wood floor. does anyone know a formula that uses linseed oil , beeswax, and something else? please reply.  thank you, lana.
  1. Piffin | Sep 20, 2006 04:32am | #1
    This will be a very slow cure rate.
    Many of the prepared finishes have polymerized linseed as a portion of the product, which cures faster and harder
    zak | Sep 20, 2006 07:54am | #2
    Danish oil finish is tried and true for wood floors.  It's part boiled linseed oil, part varnish, so it penetrates and then cures.  It doesn't leave a film on top of the floor, and maybe that's what you're looking for.
    Usually, you'll put a couple of coats of danish oil on (follow can directions- apply lots, let it soak in, then rag off the excess), then after it's cured for a while, you wax the floor.  The floor will need to be rewaxed once or twice a year.  It's certainly a higher maintanence finish than a polyurethane varnish.
    zak
    "so it goes"
  3. ditch | Sep 20, 2006 04:21pm | #3
    Waterlox. Provides a traditional oil look with the durability of a surface finish. Requires no wax or periodic buffing.
    1. Oregon | Sep 20, 2006 07:26pm | #4
      Would Waterlox resist staining from water and other spills? That and the easy maintenance are what I like about urethane, though I prefer the depth of color that oil finishes provide.
      1. ditch | Sep 20, 2006 08:13pm | #5
        Yes, it will resist water staining. It is expensive and will require a min. of 4 coats. A good system is 2 coats of sealer and 2 coats of finish.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
