I need some ideas (that work!) about how to insulate a concrete slab floor and out t&g strip flooring over it. I am looking to convert an attached garage into living space. Thank you for your help. Jim
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
a couple questions
How much ceiling ht. is in there now?
Concrete to floor level of house? Do you mind a step down, if so-how many?
How are you going to heat it?
wood floor over slab
At this point it's a theoretical house. Could be any house. I have never had a two car garage, but I suppose it's a little over eight feet. I need a studio space more than I need an attached garage. Will add a carport. I could do a tile floor with electric heat in the morter bed. Step down is not a problem. As for rules of real estate, buy low, sell high? Jim
Jim
You could for a wood floor, lay sleepers down-fasten, inlay foam sheets between and then apply a plywood subfloor. The sleepers could be leveled.
or
You could lay down full sheets of foam, then two layers of ply placed on top. You'd not need to fasten these down, but certainly could if necessary. The sheets would be staggered and glued and screwed together. You now have a surface to fasten your hardwood down to. The problem with this is that most garage concrete is pitched to a drain or out towards the door. In addition, this method might have too much flex to support a tile floor.
or
You could layout joists, thickness to be determined by how high you can go. Span of joists would be dictated by distance apart of sleepers (for tile, a stiffer floor is needed) that would be fastened to the concrete. Foam first between the sleepers, then fibreglass above and between the joists is one possibility. With this joist spacing and some creative framing, you could run forced air ducting around the room.
In any of these, you want to consider moisture transfer from slab up to finish. 6 mil visqueen lapped and taped put down first would help contain it. Some would suggest 30# felt paper put down and lapped-taping this would be a problem.
In addition, breaking the outside transfer of cold to the slab at the door opening should be considered. And, you'll need to water proof that area as well, so no moisture comes in under or saturates a wall plate placed on the slab. I'd lay a course of block or pour a curb along the opening-insert J bolts to fasten your plate to.
Plus, what are the three important things about real-estate?
Location, location, location.
Right, which, to my knowledge, has not been stated.
Quite all right.........
as he must have thought what I wrote was as worthless as tit's on a boar hog.
at least you exhibited a response.
Calvin, sorry I did not respond to your great information. It's a lot to think about. Thank you for taking the time to respond. This is a house I want to buy but am waiting for my place to close. I had not thought about the curb idea, but it makes sence. to answer Dan's question, PNW- Olypic Peninsula. Thank you again, Jim
No problem
There's alot rolling around inside my head at this time.
I'm usually a much more pleasant person................
well, sort of.
Best of luck on your project.
